Home » Eclipse Projects » Eclipse 4 » Eclipse 4 menu icon size
Eclipse 4 menu icon size [message #1007673] Wed, 06 February 2013 19:44 Go to next message
Li Chen is currently offline Li Chen
Eclipse 3.x used to have a menu icon size limit of 16 pixel. Does this change in eclipse 4?
I tried to set a 64 icon in HandledToolItem for TrimBars and still shrink to 16 pixel.
Re: Eclipse 4 menu icon size [message #1007691 is a reply to message #1007673] Thu, 07 February 2013 02:33 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk Fauth
Well I think this is related to the CSS styling. If you need to have a greater icon for toolitems, you need to change that in CSS.
As I never worked on that before, I can't give you any more details unfortunately.
Re: Eclipse 4 menu icon size [message #1007739 is a reply to message #1007673] Thu, 07 February 2013 06:14 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
In my RCP application I was and have ever been able to set bigger icons,
no matter if it is 3.x or 4.x. So I'm not sure what is happening. Could
it be that the size is calculated based on the first one set - similar
to how SWT-Table?
Tom
Am 07.02.13 01:44, schrieb Missing name Mising name:
> change in eclipse 4? I tried to set a 64 icon in HandledToolItem for
icon10.gif  Re: Eclipse 4 menu icon size [message #1008148 is a reply to message #1007673] Sun, 10 February 2013 22:50 Go to previous messageGo to next message
Thanks for the replies, I did a complete refresh of the workspace and the new icon appeared as their original size Smile
For me there is not setting required, all I did was to point the Icon URI to the correct path in Handled Tool Items.
Re: Eclipse 4 menu icon size [message #1008150 is a reply to message #1007673] Sun, 10 February 2013 23:10 Go to previous message
No Message Body
[Updated on: Sun, 10 February 2013 23:11]
Report message to a moderator
Previous Topic:Handled tool item - visible when
Next Topic:Command parameters in context menu
Current Time: Fri May 24 04:09:00 EDT 2013
Powered by FUDForum. Page generated in 0.04269 seconds
