Home » Modeling » TMF (Xtext) » Kepler TypeNotFoundException
Kepler TypeNotFoundException [message #1007731] Thu, 07 February 2013 05:52 Go to next message
Christophe Bouhier is currently offline Christophe Bouhier
Is Kepler for usage with Xtext?
I get this error on a new Xtext project and on an old one:
0 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/xtext/common/types/access/TypeNotFoundException
com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/xtext/common/types/access/TypeNotFoundException
at com.google.inject.internal.MapMaker$StrategyImpl.compute(MapMaker.java:553)
at com.google.inject.internal.MapMaker$StrategyImpl.compute(MapMaker.java:419)
at com.google.inject.internal.CustomConcurrentHashMap$ComputingImpl.get(CustomConcurrentHashMap.java:2041)
at com.google.inject.internal.FailableCache.get(FailableCache.java:46)
at com.google.inject.ConstructorInjectorStore.get(ConstructorInjectorStore.java:52)
at com.google.inject.ConstructorBindingImpl.initialize(ConstructorBindingImpl.java:57)
at com.google.inject.InjectorImpl.initializeBinding(InjectorImpl.java:377)
at com.google.inject.BindingProcessor$1$1.run(BindingProcessor.java:169)
at com.google.inject.BindingProcessor.initializeBindings(BindingProcessor.java:224)
at com.google.inject.InjectorBuilder.initializeStatically(InjectorBuilder.java:120)
at com.google.inject.InjectorBuilder.build(InjectorBuilder.java:105)
Re: Kepler TypeNotFoundException [message #1007799 is a reply to message #1007731] Thu, 07 February 2013 09:20 Go to previous messageGo to next message
Dennis Huebner is currently offline Dennis Huebner
Hi Christophe,
Xtext is tested on top of Kepler, so yes, Xtext is kepler compatible.
Which version of Xtext are you using? How do you install Xtext (which features are installed)?
Dennis.
+Dennis Hübner
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Re: Kepler TypeNotFoundException [message #1007805 is a reply to message #1007799] Thu, 07 February 2013 09:52 Go to previous message
I found the problem. It turns out if you have your own target definition, the plugins in it need to match the .mwe2 version in the Eclipse install. So MWE2.launch is taken from the target.
Works like a charm now on keppler with xtext 2.4/Mwe 2.4.
Thanks.
Previous Topic:Creating RCP, no executable
Next Topic:How do I make it so I can add decimals to the amount and quantity and also recieve a correct decimal
Current Time: Thu May 23 00:03:25 EDT 2013
Powered by FUDForum. Page generated in 0.08159 seconds
