Home » Eclipse Projects » Jubula » test rcp application
test rcp application [message #1007284] Tue, 05 February 2013 06:12 Go to next message
khalil alrifai is currently offline khalil alrifai
hello,
I want to test a rcp application with Jubula, I need to specify a username and password to start this application. The aut-agent will not start until I logged me. My question is: how can I test this registration process with Jubula?
Kind regards,
khalil
Re: test rcp application [message #1007491 is a reply to message #1007284] Wed, 06 February 2013 02:30 Go to previous messageGo to next message
Alexandra Schladebeck is currently offline Alexandra Schladebeck
You'll need to enter the login details in the AUT configuration as "AUT arguments" using the -data parameter. More information is in this thread.
HTH,
Alex
Re: test rcp application [message #1007547 is a reply to message #1007491] Wed, 06 February 2013 06:50 Go to previous messageGo to next message
thank you for your answer
can you show me an example how I can specify this login data with the paramter -data
Kind regards,
khalil
Re: test rcp application [message #1007702 is a reply to message #1007547] Thu, 07 February 2013 03:11 Go to previous message
Hi Khalil,
I'm afraid I can't - I've personally never worked with an AUT that does that before. However, if you (or someone on your team) can start the AUT via the command line using parameters for the login details, then I reckon those will be what you need.
HTH,
Alex
Previous Topic:How to check multiple line text in jubula?
Next Topic:Why jubula could not check multiple text in my textbox ?
Current Time: Fri May 24 03:35:08 EDT 2013
Powered by FUDForum. Page generated in 0.01749 seconds
