| [CDO] importer Exception [message #1007597] |
Wed, 06 February 2013 11:51  |
Christophe Bouhier Messages: 683 Registered: July 2009 |
See the exception when importing an xml file exported by CDO.
Does CDO produce XML it can not import later on?
here is a snippet of the produced XML:
<feature name="message" value="Could not locate identifier for metric STP_SCPKTSNT. For identifiers: - NODE: arnstp01 - FUNCTION: <=�����, Failed on : - FUNCTION: <=�����"/>
That's bizar encoding, this value.
This is the code which writes this feature:
final StringBuilder sb = new StringBuilder();
sb.append("Could not locate networkElement for metric "
+ metric.getName());
sb.append("Using identifiers: ");
for (final IComponentLocator.IdentifierDescriptor idValue : identifierValues) {
sb.append(" - " + idValue.getKind().getObjectKind().getName()
+ ": " + idValue.getValue());
Anything unusual?
org.xml.sax.SAXParseException: Character reference "" is an invalid XML character.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:195)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:174)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:388)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1414)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.scanCharReferenceValue(XMLScanner.java:1298)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.scanAttributeValue(XMLScanner.java:851)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanAttribute(XMLDocumentFragmentScannerImpl.java:1547)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1320)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2756)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:648)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:511)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:198)
at org.eclipse.emf.cdo.server.CDOServerImporter$XML.importAll(CDOServerImporter.java:329)
at org.eclipse.emf.cdo.server.CDOServerImporter.importRepository(CDOServerImporter.java:111)
at org.eclipse.emf.cdo.internal.server.bundle.CDOCommandProvider.importXML(CDOCommandProvider.java:230)
at org.eclipse.emf.cdo.internal.server.bundle.CDOCommandProvider._cdo(CDOCommandProvider.java:110)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.osgi.framework.internal.core.FrameworkCommandInterpreter.execute(FrameworkCommandInterpreter.java:209)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.docommand(FrameworkConsole.java:155)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.runConsole(FrameworkConsole.java:140)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.run(FrameworkConsole.java:104)
at java.lang.Thread.run(Thread.java:662)
FUDForum. Page generated in 0.02180 seconds
