Home » Modeling » EMF » [CDO] importer Exception
[CDO] importer Exception [message #1007597] Wed, 06 February 2013 11:51 Go to next message
Christophe Bouhier is currently offline Christophe Bouhier
See the exception when importing an xml file exported by CDO.
Does CDO produce XML it can not import later on?
here is a snippet of the produced XML:
<feature name="message" value="Could not locate identifier for metric STP_SCPKTSNT. For identifiers:  - NODE: arnstp01 - FUNCTION: &lt;=�����, Failed on :  - FUNCTION: &lt;=�����"/>
That's bizar encoding, this value.
This is the code which writes this feature:
final StringBuilder sb = new StringBuilder();
		sb.append("Could not locate networkElement for metric "
				+ metric.getName());
		sb.append("Using identifiers: ");
		for (final IComponentLocator.IdentifierDescriptor idValue : identifierValues) {
			sb.append(" - " + idValue.getKind().getObjectKind().getName()
					+ ": " + idValue.getValue());
Anything unusual?
org.xml.sax.SAXParseException: Character reference "&#1" is an invalid XML character.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:195)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:174)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:388)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1414)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.scanCharReferenceValue(XMLScanner.java:1298)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.scanAttributeValue(XMLScanner.java:851)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanAttribute(XMLDocumentFragmentScannerImpl.java:1547)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1320)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2756)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:648)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:511)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:198)
at org.eclipse.emf.cdo.server.CDOServerImporter$XML.importAll(CDOServerImporter.java:329)
at org.eclipse.emf.cdo.server.CDOServerImporter.importRepository(CDOServerImporter.java:111)
at org.eclipse.emf.cdo.internal.server.bundle.CDOCommandProvider.importXML(CDOCommandProvider.java:230)
at org.eclipse.emf.cdo.internal.server.bundle.CDOCommandProvider._cdo(CDOCommandProvider.java:110)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.osgi.framework.internal.core.FrameworkCommandInterpreter.execute(FrameworkCommandInterpreter.java:209)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.docommand(FrameworkConsole.java:155)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.runConsole(FrameworkConsole.java:140)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.run(FrameworkConsole.java:104)
at java.lang.Thread.run(Thread.java:662)
Re: [CDO] importer Exception [message #1007641 is a reply to message #1007597] Wed, 06 February 2013 15:47 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Am 06.02.2013 17:51, schrieb Christophe Bouhier:
> See the exception when importing an xml file exported by CDO. Does CDO produce XML it can not import later on?
That's not the goal :P
> - FUNCTION: <=�����, Failed on : - FUNCTION: <=�����"/>
Hm, is "<" allowed in attribute values?
I checked that the exporter uses this to output the XML:
SAXTransformerFactory factory = (SAXTransformerFactory)SAXTransformerFactory.newInstance();
xmlHandler = factory.newTransformerHandler();
So, all needed conversion and escaping should be done there. I'm not an expert in XML or SAX. Maybe Ed has an idea...
Cheers
/Eike
http://www.esc-net.de
> Anything unusual?
> at
> at
> at
> at
> at
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
Re: [CDO] importer Exception [message #1007644 is a reply to message #1007597] Wed, 06 February 2013 16:05 Go to previous messageGo to next message
It looks like a very normal non 8-bit to 8-bit character coding mismatch.
You created a Java string, but what did you do with it then?
Ed Willink
Re: [CDO] importer Exception [message #1007665 is a reply to message #1007641] Wed, 06 February 2013 17:51 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
XML 1.0 does not allow as many characters as does XML 1.1 so maybe
specifying OPTION_XML_VERSION as 1.1 will allow the characters you've
included. Note that even XML 1.1 doesn't allow &#0;. I'd definitely
expect any < in the string to be encoded as &lt;...
>> identifierValues) {
>> sb.append(" - " +
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Anything unusual?
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
Re: [CDO] importer Exception [message #1007708 is a reply to message #1007665] Thu, 07 February 2013 03:35 Go to previous message
The snippet of XML, is also decoded by the forum! The '<' is not the problem. In my snippet it's a "&lt;"
The problem occurs on this character "" (As you see in the exception). It's indeed an invalid XML 1.0 control character.
I submitted this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=400182
Cheers Christophe
Previous Topic:[CDO] NPE exporting from CDO
Next Topic:[Teneo] EntityInterfaceNameStrategy not setting Enumerations as expected
Current Time: Sat May 25 02:26:16 EDT 2013
Powered by FUDForum. Page generated in 0.01763 seconds
