Home » Eclipse Projects » BPMN 2.0 Modeler » Remove shelf from pallette
Remove shelf from pallette [message #1007566] Wed, 06 February 2013 09:06 Go to next message
Rui Domingues is currently offline Rui Domingues
Hi. Is that possible to remove an entire shelf from palette via xml?
I'm able to remove objects one by one, but how do I remove a shelf.
Actually I tried to remove the content of DataItems Shelf:
DataStore
DataInput
DataObject
DataOutput,
but DataStore remains there, maybe because it is required by some other object.
Anyway i'd like to remove the shelf itself.
Thanks in advance.
Re: Remove shelf from pallette [message #1007589 is a reply to message #1007566] Wed, 06 February 2013 10:36 Go to previous message
Robert Brodt is currently offline Robert Brodt
Hi Rui,
Currently the only way to remove a palette "drawer" is to disable all of the model elements individually. It sounds like this is the approach you have taken but I'm not sure why DataStore will not go away. You can try disabling the model elements one-by-one from the Project Properties dialog->BPMN2->Tool Enabled and restart the editor until the drawer disappears.
The Tool Enablement project preference looks like this:
http://content.screencast.com/users/rbrodt/folders/Jing/media/564eafc0-b69d-4272-8a07-154db3db1d43/2013-02-06_0833.png
Be sure to enable the "Override" checkbox and click the "Copy" button at the bottom.
The toolpalette configuration still needs work, so feel free to submit an enhancement request!
Bob
Previous Topic:Own Extensions for the metamodel & modeler
Next Topic:Stacktrace on right click.
Current Time: Tue May 28 23:12:20 EDT 2013
Powered by FUDForum. Page generated in 0.01520 seconds
