| Re: ATL Refining Using the API [message #988387 is a reply to message #988361] |
Thu, 29 November 2012 12:16   |
Ronan B Messages: 194 Registered: July 2009 |
Finally, I have figured it out! There is a really hard to find bug in the LauncherService.java getModel method. There is a bad assumption that the IN model and its associated MetaModel will have the same injector. This is not the case when doing ATL HOTs.
The ATL MM should use an EMF injector while the ATL model should use an ATL injector. Today in the code they always use the same one.
Replace the line injector.inject(referenceModel, referenceModelPath); with CoreService.getInjector("EMF").inject(referenceModel, referenceModelPath); and all will work beautifully!
I'll raise a bug in Bugzilla for this next week and submit a patch. To the ATL guys, can we get this into the next ATL release? This is a very important fix for me.
Ronan
[Updated on: Thu, 29 November 2012 15:21] Report message to a moderator
| Re: ATL Refining Using the API [message #1007531 is a reply to message #1007349] |
Wed, 06 February 2013 05:45  |
Greg L Messages: 9 Registered: November 2012 |
Junior Member |
Hi Sylvain,
Thank you for you suggestion. However, the problem has to be different.
My xmi file looks like this: (this is a fragment of it)
<elements xsi:type="atl:SimpleOutPatternElement" location="277:3-281:4" varName="connected_Output_Param" variableExp="/0/@elements.4/@outPattern/@elements.29/@bindings.2/@value">
<commentsBefore>--- connect value</commentsBefore>
<type xsi:type="ocl:OclModelElement" location="277:27-277:50" name="ConnectedElement" model="/63"/>
<bindings location="279:4-279:83" propertyName="connectionEnd">
<value xsi:type="ocl:IteratorExp" location="279:19-279:83" name="any">
<source xsi:type="ocl:NavigationOrAttributeCallExp" location="279:19-279:56" name="ownedParameter">
<source xsi:type="ocl:VariableExp" location="279:19-279:41" referredVariable="/0/@elements.4/@variables.6"/>
</source>
<body xsi:type="ocl:OperatorCallExp" location="279:66-279:82" operationName="=">
<source xsi:type="ocl:NavigationOrAttributeCallExp" location="279:66-279:72" name="name">
<source xsi:type="ocl:VariableExp" location="279:66-279:67" referredVariable="/0/@elements.4/@outPattern/@elements.27/@bindings.0/@value/@iterators.0"/>
</source>
<arguments xsi:type="ocl:StringExp" location="279:75-279:82" stringSymbol="value"/>
</body>
<iterators location="279:62-279:63" varName="e" variableExp="/0/@elements.4/@outPattern/@elements.27/@bindings.0/@value/@body/@source/@source"/>
</value>
</bindings>
<bindings location="280:4-280:25" propertyName="context">
<value xsi:type="ocl:VariableExp" location="280:13-280:25" referredVariable="/0/@elements.4/@outPattern/@elements.13"/>
</bindings>
</elements>
As you can see, the OperatorCallExp has operationName attribute present. This applies to the entire file.
The problem is that I am trying to run the XMI to ATL conversion from a standalone java application. This conversion, however, works fine from an atl plugin.
To make the tcs.extractor work I first register the needed MetaModels in the following way:
getResourceSet().getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
getResourceSet().getResourceFactoryRegistry().getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
URI ecoreURITCS = URI.createFileURI("Meta/TCS.ecore");
Resource resourcePackageTCS = resourceSet.getResource(ecoreURITCS, true);
EPackage ePackageTCS = (EPackage)resourcePackageTCS.getContents().get(0);
EPackage.Registry.INSTANCE.put("http://www.eclipse.org/gmt/tcs/2007/TCS", ePackageTCS);
URI ecoreURIat = URI.createFileURI("Meta/ATL-TCS.xmi");
Resource resourcePackageTCSat = resourceSet.getResource(ecoreURIat, true);
EObject ePackageAT = resourcePackageTCSat.getContents().get(0);
EPackage.Registry.INSTANCE.put("http://www.eclipse.org/gmt/tcs/2007/TCS", ePackageAT);
URI ecoreURIATL = URI.createFileURI("Meta/ATL.ecore");
Resource resourcePackage = resourceSet.getResource(ecoreURIATL, true);
EPackage ePackageOCL = (EPackage)resourcePackage.getContents().get(1);
EPackage.Registry.INSTANCE.put("http://www.eclipse.org/gmt/2005/OCL", ePackageOCL);
EPackage ePackageATL = (EPackage)resourcePackage.getContents().get(0);
EPackage.Registry.INSTANCE.put("http://www.eclipse.org/gmt/2005/ATL", ePackageATL);
EPackage ePackagePT = (EPackage)resourcePackage.getContents().get(2);
EPackage.Registry.INSTANCE.put("http://www.eclipse.org/gmt/2005/PrimitiveTypes", ePackagePT);
getResourceSet().getPackageRegistry().put("http://www.omg.org/XMI", EcorePackage.eINSTANCE);
getResourceSet().getPackageRegistry().put("http://www.w3.org/2001/XMLSchema-instance", EcorePackage.eINSTANCE);
So, the extractor gets the correct MetaModels injected, and the XMI file is also correct. Any ideas, why it fails?
Thank you in advance for any tip or suggestion!
Greg L
FUDForum. Page generated in 0.02562 seconds
