| Binding two EMF objcets [message #1007472] |
Tue, 05 February 2013 22:25 |
Ramesh Nachimuthu Messages: 10 Registered: May 2012 |
Junior Member |
We have a scenario where attributes in two EMF objects should be in sync always. But there is no reference relationship between them. For example
Value of attribute A in EMF object X should always in sync with value of attribute B in object Y. User can change this to make attribute A in X to refer to attribute C in Z object through property sheet. objects X,Y and Z are all of same class. We have a Form based editor to open the resource which contains all these objects. Can we achieve this binding using EMF data binding between two model attributes?
Ramesh
FUDForum. Page generated in 0.02016 seconds
