Home » Modeling » Model-to-Model Transformation » Large Model, minor changes
Large Model, minor changes [message #1007067] Mon, 04 February 2013 05:19 Go to next message
Matthias N is currently offline Matthias N
Member
I haven't done very much in M2M, but before I start, I want to have your opinion:
We have a very big Ecore meta-model (~500 classes), lets call it "A".
Now, we have another Ecore meta-mdoel ("B"), which is almost similiar to "A" but does have about 20 deviations.
What I now want to do is to transform "B" -> "A" and "A" -> "B".
Can you tell me what the best approach would be and how complex this would be?
Thank you very much
Matthias
Re: Large Model, minor changes [message #1007075 is a reply to message #1007067] Mon, 04 February 2013 05:49 Go to previous messageGo to next message
500 classes is not 'very big'. The corresponding model with 500,000
objects might be.
Ideally you want a bidirectional transformation language such as QVTr,
however the main Eclipse implementations only support editing today. You
could try the Medini or ModelMorf implementations.
Alternatively you can implement two unidirectional transformations, in
which case your choices are at least
- QVTo (most standard)
- ATL (most mature)
- Xtend2 (most Java-like)
- Epsilon (most diverse)
- Viatra2 (most unknown to me)
With only 20 deviations, handcrafted Java and mapping tools may also be
options
Ed Willink
On 04/02/2013 10:19, Matthias N wrote:
> your opinion:
> would be?
> Thank you very much
> Matthias
Re: Large Model, minor changes [message #1007079 is a reply to message #1007075] Mon, 04 February 2013 06:16 Go to previous messageGo to next message
Member
Hi Ed,
thank you very much for your answer.
Is it possible to only define the deviations in the M2M transformatino language, or do I really have to specify every transformation rule of the entire meta-model by hand?
Re: Large Model, minor changes [message #1007095 is a reply to message #1007079] Mon, 04 February 2013 07:42 Go to previous messageGo to next message
I don't really understand the question.
Some transformations languages have a default copy behaviour so that you
only need to worry about differences.
Ed Willink
On 04/02/2013 11:16, Matthias N wrote:
> Hi Ed,
Re: Large Model, minor changes [message #1007438 is a reply to message #1007095] Tue, 05 February 2013 15:56 Go to previous message
Dennis Wagelaar is currently offline Dennis Wagelaar
Member
Op 04-02-13 13:42, Ed Willink schreef:
> Hi
> Some transformations languages have a default copy behaviour so that you only
> Regards
> Ed Willink
>> Hi Ed,
For the ATL solution, see this thread:
http://www.eclipse.org/forums/index.php/m/535170/
Dennis
Previous Topic:org.eclipse.emf.mwe.utils.Reader is not working
Next Topic:"Many-Model to Model" transformation with qvto?
Current Time: Tue May 28 20:21:01 EDT 2013
Powered by FUDForum. Page generated in 0.01546 seconds
