| Connect to Microsoft Access via Data Explorer in IDE [message #1007209] |
Mon, 04 February 2013 19:30  |
Sean Westerfield Messages: 3 Registered: February 2013 |
Junior Member |
Greetings all,
I am evaluating Eclipse for use in my organization. I need to use multiple data sources, including MS Access. I cannot find any information on how to use Microsoft Access via the IDE, just how to do it via code. I understand there is a JDBC-ODBC bridge that is apparently bundled with Eclipse, but I don't know how to add the driver so that I can select it when adding a new data source, or if this is even the way to go about it. I have virtually no experience, with Eclipse, Java, or Tomcat, so I really need some thorough information as to where to click, what to type, etc. Any help will be greatly appreciated!
Thanks!
| Re: Connect to Microsoft Access via Data Explorer in IDE [message #1007333 is a reply to message #1007209] |
Tue, 05 February 2013 09:49   |
Russell Bateman Messages: 2711 Registered: July 2009 Location: Provo, Utah, USA |
On 2/5/2013 6:52 AM, Sean Westerfield wrote:
> Greetings all,
> appreciated!
> Thanks!
There's a separate forum for Eclipse data tools where you might get more
and better help with this.
FUDForum. Page generated in 0.01585 seconds
