| Newbie Question [message #1007404] |
Tue, 05 February 2013 13:22  |
Iain Wilson Messages: 3 Registered: February 2013 |
Junior Member |
I have an RCP based editor where the editor page uses the master-details pattern. I currently have a page-flow editor for web based wizard definition implemented using Zest but would like to upgrade to use Graphiti. Can a Graphiti editor be implemented within an IDetailsPage - documentation I have sen suggests not but I wondered whether anyone in the wider community had done this?
| Re: Newbie Question [message #1008283 is a reply to message #1007592] |
Mon, 11 February 2013 02:49   |
Michael Wenz Messages: 1267 Registered: July 2009 Location: Walldorf, Germany |
Iain,
that's ok, at least these are just question and I can try to answer them...
The next release of Graphiti will happen in June together with Eclipse
Kepler, that's the part that is for sure. I do not yet know if the diagrams
in views feature will become part of that, because the thing just started
and there is still quite some work involved to get that sorted out with e.g.
respect to compatibility. And feature freeze is soon, M6 is the milestone
for this and it is due March 22nd.
Regarding compatibility with Eclipse 3.7, the answer is also I'm not sure:
usually we support the current Eclipse version and the one before with a new
release of Graphiti. For the Graphiti Kepler release that would mean Kepler
(4.3) and Juno (4.2/3.8). So far there were no changes in the APIs of the
projects we use that forced us to require a higher version than what's in
Eclipse 3.7 and actually we didn't increase the required version numbers so
far. So, currently the upcoming Graphiti version for Kepler would still be
compatible with 3.7. But that might still change and we usually do not test
against a 2 version back Eclipse.
HTH,
Michael
FUDForum. Page generated in 0.02148 seconds
