Home » Eclipse Projects » BIRT » Custom SQL as a parameter(User can write custom sql where condition in parameter)
Custom SQL as a parameter [message #1007138] Mon, 04 February 2013 10:26 Go to next message
Tomas Greif is currently offline Tomas Greif
Member
I would like to create a parameter linked to dataset parameters. This parameter should be used in WHERE clause of SQL statement. In other words I would like to create the following (example) dataset:
select * from table where ?
Where ? is dataset parameter linked to report parameter where default value for report parameter is 1=1
If I use such approach then ? in SQL is replaced correctly (I guess) by parameter value (I have set default value for parameter). However the error I get back is:
Failed to prepare the query execution for the data set: VintageData
Cannot get the result set metadata.
    org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
SQL error #1: ERROR: argument of WHERE must be type boolean, not type character varying
Is there a way how can I make this work?
We are using BIRT 2.6.1 and PostgreSQL 9.1
Re: Custom SQL as a parameter [message #1007215 is a reply to message #1007138] Mon, 04 February 2013 23:41 Go to previous messageGo to next message
Michael Williams is currently offline Michael Williams
You could instead use a query like, "select * from table". Then, in your beforeOpen script of your dataSet, you'd put something like:
this.queryText = this.queryText + " where " + params["whereParam"];
You'll need to make sure that the sql in the parameter is formatted correctly, somehow, or it will break.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Custom SQL as a parameter [message #1007242 is a reply to message #1007215] Tue, 05 February 2013 03:27 Go to previous messageGo to next message
Member
Hi Michael,
this works perfect!
Thank you.
Tomas
Re: Custom SQL as a parameter [message #1007337 is a reply to message #1007242] Tue, 05 February 2013 10:05 Go to previous message
You're welcome!
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:Gantt chart multiple timeframes per series
Next Topic:library to display graphs
Current Time: Sat May 25 03:15:30 EDT 2013
Powered by FUDForum. Page generated in 0.01621 seconds
