Home » Eclipse Projects » Hudson » Hudson 3.0 --> "Test report" graph is always blue
Hudson 3.0 --> "Test report" graph is always blue [message #1007329] Tue, 05 February 2013 09:44 Go to next message
Aurelien Pupier is currently offline Aurelien Pupier
I have some test failing and some skipped tests but the graph is completely blue.
We can distinguish a white lane at the separation between each amount of test.
See attached screenshot:
http://img255.imageshack.us/img255/1848/hudsontestreportissue.png
Configuration:
Hudson 3.0
on Linux Ubuntu
I tested to display it on Windows 8 with Chrome and Firefox.
I saw no error in /var/log/hudson/hudson.log file.
Plugins are all up-to-date.
Do you have an idea of what is happening? How can I investigate deeper on this issue?
Aurélien Pupier - BonitaSoft S.A.
My blog
My company Eclipse-related blog
Re: Hudson 3.0 --> "Test report" graph is always blue [message #1007372 is a reply to message #1007329] Tue, 05 February 2013 11:26 Go to previous messageGo to next message
Winston Prakash is currently offline Winston Prakash
I believe this is a bug in Hudson 3.0.0. It uses Eclipse BIRT for charting. Appears instead of creating stacked area chart, it is using just area chart. Since the successful builds are larger than other two, it covers the other two. I will investigate and fix this. Meanwhile it may be possible to revert to old chart style (2.2.x) based on JFreeChart, by disabling the birt-chart plugin and installing the jfreechart plugin.
I think this is the bug what you are seeing https://bugs.eclipse.org/bugs/show_bug.cgi?id=399405
Winston Prakash
Eclipse Hudson team
Re: Hudson 3.0 --> "Test report" graph is always blue [message #1007373 is a reply to message #1007372] Tue, 05 February 2013 11:33 Go to previous message
effectively, it seems to be the same issue. Sorry not to have searched correctly in the bugtracker for existing issue.
My blog
Previous Topic:Hudson + TestNG + Selenium/Java
Next Topic:some workspaces are being automatically deleted
Current Time: Mon May 20 13:30:41 EDT 2013
Powered by FUDForum. Page generated in 0.02486 seconds
