Home » Modeling » MoDisco » Help with KDM transformation
Help with KDM transformation [message #1007297] Tue, 05 February 2013 07:27 Go to next message
Rafael Durelli is currently offline Rafael Durelli
Member
I have two metamodel a SQL Model and a KDM Data package. The former contains three metaclasses DataBase, Table and Column. The latter represents the artifacts related to persistent data, such as indexed files, relational databases, and other kinds of data storage.
In this context, I would like to transform the first metamodel (SQL Model) to the KDM Data package. Thus, I have created the following atl code.
-- @path MM=/SQLMODEL/model/sqlmodel.ecore
-- @nsURI MM1=http://www.eclipse.org/MoDisco/kdm/data
-- @nsURI MM1=http://www.eclipse.org/MoDisco/kdm/code
module teste;
create OUT : MM1 from IN : MM;
rule dataBase2RelationalSchema {
	from
		t : MM!Database
	to
		r : MM1!RelationalSchema (
			name <- t.name,
			dataElement <- t.tables
rule table2RelationalTable {
	from
		t : MM!Table
	to
		r : MM1!RelationalTable (
			name <- t.name,
		 	dataElement <- t.columns
rule column2ColumnSet {
	from
		t : MM!Column
	to
		r : MM1!ColumnSet (
			name <- t.name,
			itemUnit <- item
		item : MM1!ItemUnit (
			type <- type
		type : MM1!Datatype (
			name <- t.type
However it is not complete all Datatype is been generated without an id. Someone has an example ?
Thanks in advance.
Re: Help with KDM transformation [message #1007316 is a reply to message #1007297] Tue, 05 February 2013 08:55 Go to previous message
Hugo Bruneliere is currently offline Hugo Bruneliere
Similarly to http://www.eclipse.org/forums/index.php/t/452602/, what do you mean by "it is not complete all Datatype is been generated without an id"?
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Previous Topic:Generate Java code from a Java model
Next Topic:How to process my KDM models
Current Time: Tue May 28 18:50:59 EDT 2013
Powered by FUDForum. Page generated in 0.01794 seconds
