Home » Eclipse Projects » Rich Client Platform (RCP) » How enable and disable buttons using event in SWT.(How enable and disable buttons using event in SWT.)
How enable and disable buttons using event in SWT. [message #1006467] Thu, 31 January 2013 07:16 Go to next message
sumit singh is currently offline sumit singh
Member
I'm creating one swt project . In that i have 1 dialog with 4 buttons.
What i need:
With one Button which is enable if i click then other will enable and this will disable.
And again from other button if i click all other should disable and 1st one should enable.
How I'm doing
Simple way to do this is create one function which invert the visibility. and call that method from widget Selection event.
What i want
Is there is any other way (Standard) to do this like using fireevent.
Re: How enable and disable buttons using event in SWT. [message #1006475 is a reply to message #1006467] Thu, 31 January 2013 07:45 Go to previous messageGo to next message
Simon SSC is currently offline Simon SSC
Member
Hi sumit,
the JFace Databinding might be an alternative :
DataBindingContext dbc = new DataBindingContext();
        Button button1 = new Button(parent, SWT.PUSH);
        Button button2 = new Button(parent, SWT.PUSH);
        ISWTObservableValue observeEnabledButton1 = SWTObservables.observeEnabled(button1);
        ISWTObservableValue observeEnabledButton2 = SWTObservables.observeEnabled(button2);
        UpdateValueStrategy updateValueStrategy = new UpdateValueStrategy();
        updateValueStrategy.setConverter(new IConverter() {
            public Object getToType() {
                return Boolean.TYPE;
            public Object getFromType() {
            public Object convert(Object fromObject) {
                if(fromObject instanceof Boolean){
                    // return inverse to disable the other button
                    return ((Boolean) fromObject).booleanValue() ? Boolean.FALSE : Boolean.TRUE;
                return Boolean.FALSE;
        dbc.bindValue(observeEnabledButton1, observeEnabledButton2, updateValueStrategy, updateValueStrategy);
With that solution the enabled state of button1 is always the oppisite of the enabled state of button2 and the other way round.
So with that binding you only need to disable the button you just clicked and the other button will be enabled automatically by the binding.
@see JFace Databinding
Hope that helps and it is what you have asked for.
Simon
Re: How enable and disable buttons using event in SWT. [message #1006480 is a reply to message #1006475] Thu, 31 January 2013 08:07 Go to previous messageGo to next message
Member
Thnaks Simon,
I'll try it.
Re: How enable and disable buttons using event in SWT. [message #1006586 is a reply to message #1006467] Thu, 31 January 2013 18:43 Go to previous messageGo to next message
Member
Hey sumit,
you´re welcome.
If you have any further questions do not hesitate to ask Wink
Simon
Re: How enable and disable buttons using event in SWT. [message #1006653 is a reply to message #1006586] Fri, 01 February 2013 05:34 Go to previous messageGo to next message
Member
Hi Simon,
Sorry for asking you again.
I tried your code, at starting time it works means button1 is disable and button2 is enable. But if i click button2 and its listener am disabling it but other button is still in disable mode . I'm putting my code:
Button button1 = new Button(parent, SWT.NONE);
button1.setText("hello");
final Button button2 = new Button(parent, SWT.NONE);
button2.addSelectionListener(new SelectionAdapter() {
		public void widgetSelected(SelectionEvent e) {
		     button2.setEnabled(false);
button2.setText("world");
	    if (fromObject instanceof Boolean) {
[Updated on: Fri, 01 February 2013 05:34]
Report message to a moderator
Re: How enable and disable buttons using event in SWT. [message #1007235 is a reply to message #1006653] Tue, 05 February 2013 03:16 Go to previous message
Member
Hi sumit,
It is my fault.
Actually there is no enabled listener available for controls, so that you need to bind the selection of the button to the other´s enabled observable.
So this code should do the job Wink
ISWTObservableValue observeSelectionButton1 = SWTObservables.observeSelection(button1);
dbc.bindValue(observeSelectionButton1, observeEnabledButton2);
Simon
Previous Topic:E4 RCP Part createContents gets executed multiple times
Next Topic:Help Home depending on user language
Current Time: Fri May 24 18:16:07 EDT 2013
Powered by FUDForum. Page generated in 0.02696 seconds
