Home » Language IDEs » Java Development Tools (JDT) » Integrate a barcode generator in my java program
Integrate a barcode generator in my java program [message #870878] Thu, 10 May 2012 03:10 Go to next message
Victoria wiliam is currently offline Victoria wiliam
Hi,all. I wanna integrate barcode generator in my Java project. Do you have any ideas on how to generate a specific barcode using a barcode generator into a Java program which can be easily read out with a barcode read
Re: Integrate a barcode generator in my java program [message #870922 is a reply to message #870878] Thu, 10 May 2012 05:19 Go to previous messageGo to next message
Gabriel wiliam is currently offline Gabriel wiliam
I suggest, you need to get the details on your barcode generator. I guess each of them has their characteristics and need to be handled in different ways.
Re: Integrate a barcode generator in my java program [message #871127 is a reply to message #870922] Thu, 10 May 2012 23:21 Go to previous messageGo to next message
linda joucs is currently offline linda joucs
I have ever seen some jar files included in the java barcode generation package which can be easily added into the java program...You may try the jar file and add it into your java application.
Re: Integrate a barcode generator in my java program [message #871145 is a reply to message #870878] Fri, 11 May 2012 03:12 Go to previous messageGo to next message
rufus david is currently offline rufus david
Search for "executable jar" and just run a main method of some class inside your java program which can support you do what you want.And make sure which barcode type you will choose.
Re: Integrate a barcode generator in my java program [message #900978 is a reply to message #871145] Thu, 09 August 2012 05:40 Go to previous messageGo to next message
lighting wang is currently offline lighting wang
Right. i have ever met this situation and i found a barcode solution from Terrek.com. Its Java Barcode generator can be easily integrate barcoding features into you Java applications. You may try the FREE version.
Re: Integrate a barcode generator in my java program [message #993968 is a reply to message #870878] Tue, 25 December 2012 21:41 Go to previous messageGo to next message
Becky Mars is currently offline Becky Mars
I happen to know a barcode generator for java, but I am not sure it works for your project.Here a link that you could use a free trial package.
www.barcodelib.com/java_barcode/main.html
Re: Integrate a barcode generator in my java program [message #1007221 is a reply to message #870878] Tue, 05 February 2013 01:13 Go to previous message
johanson alex is currently offline johanson alex
I am using the Barcode Generator for Java.
I think it's easy to control, meybe you can have a try this component.www.businessrefinery.com/products/barcode/main.html
If you need to read the barcode , you should use USB.
Hope it helps!
Previous Topic:Monitoring changes to JDT project-specific settings
Next Topic:Java completion proposal
Current Time: Sat May 18 11:42:32 EDT 2013
Powered by FUDForum. Page generated in 0.01768 seconds
