Home » Eclipse Projects » BIRT » How to select 2 nodes in XML Dataset(Tried setting xpath to //class1|//class2 but it doesn't match)
How to select 2 nodes in XML Dataset [message #1007204] Mon, 04 February 2013 18:26 Go to next message
Brad M is currently offline Brad M
Tried setting xpath (Row Mapping in edit DataSet) to //class1|//class2 but it doesn't match. I get the message on the Column Mapping screen that says: "The table mapping XPath does not exist"
Is there a way to do it?
Brad
Re: How to select 2 nodes in XML Dataset [message #1007226 is a reply to message #1007204] Tue, 05 February 2013 01:50 Go to previous messageGo to next message
Michael Williams is currently offline Michael Williams
Can you show a sample xml file and what you're looking for the result set to be?
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: How to select 2 nodes in XML Dataset [message #1007474 is a reply to message #1007226] Tue, 05 February 2013 22:30 Go to previous messageGo to next message
Sample XML:
<root>
	<sampleA>
		<truck>
			<type>alpha</type>
			<wheels>16</wheels>
		</truck>
		<truck>
			<type>beta</type>
			<wheels>14</wheels>
		</truck>
		<car>
			<type>phi</type>
			<wheels>4</wheels>
		</car>
	</sampleA>
	<sampleB>
		<truck>
			<type>gamma</type>
			<wheels>12</wheels>
		</truck>
		<car>
			<type>omega</type>
			<wheels>4</wheels>
		</car>
	</sampleB>
</root>
Example XML and report attached. Attempted to match //truck|//car but get the aforementioned error
Note using BIRT designer 2.6.2 (upgrade path restricted)
Re: How to select 2 nodes in XML Dataset [message #1007650 is a reply to message #1007474] Wed, 06 February 2013 16:31 Go to previous messageGo to next message
Try this as your row mapping expression "/root/*/*"
Then, use //type and //wheels as your columns. That should get you everything.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: How to select 2 nodes in XML Dataset [message #1007659 is a reply to message #1007650] Wed, 06 February 2013 17:26 Go to previous messageGo to next message
Thanks Michael.
I gave an oversimplified example though. What if I want to ignore <bicycle> siblings of car and truck?
Re: How to select 2 nodes in XML Dataset [message #1007667 is a reply to message #1007659] Wed, 06 February 2013 18:00 Go to previous messageGo to next message
Will filtering work as a workaround? It appears that the '|' character is not liked by BIRT. I'll let you know if I get something working.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: How to select 2 nodes in XML Dataset [message #1007879 is a reply to message #1007667] Thu, 07 February 2013 16:56 Go to previous messageGo to next message
Filtering isn't an option unfortunately. A closer workaround would be to search for all instances of a common child element, then referencing its parent:
//nodeUniqueToThoseIWant/..
But this doesn't work either
Looks like I might have to preprocess the data before BIRT
Re: How to select 2 nodes in XML Dataset [message #1007887 is a reply to message #1007879] Thu, 07 February 2013 17:59 Go to previous messageGo to next message
Ok. If you have a node that is unique to only the ones you want, you should be able to do something like:
//nodeUniqueToThoseYouWant as the row expression.
Then, for the columns, you'd just do ../fieldName1, ../fieldName2, etc.
In this example, I added a <bike> to the xml and added a node to the cars and trucks called property. So, my row xpath was //property and my columns were ../type and ../wheels. This gave me the data for only the cars and trucks that had this node, "property". Hopefully this helps.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: How to select 2 nodes in XML Dataset [SOLVED] [message #1007898 is a reply to message #1007887] Thu, 07 February 2013 21:41 Go to previous messageGo to next message
Hey Michael, that's done it! Just had to check 'suppress duplicates' on the table columns to hide dups and we're in business
Thanks a lot for your help
Brad
[Updated on: Thu, 07 February 2013 21:42]
Report message to a moderator
Re: How to select 2 nodes in XML Dataset [SOLVED] [message #1007901 is a reply to message #1007898] Thu, 07 February 2013 23:31 Go to previous message
Awesome! Glad to help!
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:Hierarchy error
Next Topic:sqljdbc_auth.dll already loaded in another classloader
Current Time: Sat May 25 18:08:05 EDT 2013
Powered by FUDForum. Page generated in 0.01678 seconds
