Home » Modeling » EMF » [CDO][Teneo] How to write / read LOB data stream based?
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006937 is a reply to message #1006840] Sun, 03 February 2013 00:15 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Am 02.02.2013 19:38, schrieb KW:
> I was able to use the Blob type from the etypes in my model, regenerated everything with a clean db, and when the
> first commit is called, following error on server side:
> [ERROR] Rollback in HibernateStore: org.eclipse.emf.teneo.annotations.parser.AnnotationParserException: The eclass:
> HbAnnotatedEPackage does not have an efeature for Lob
To me this looks like a problem in Teneo. Martin?
Cheers
/Eike
http://www.esc-net.de
> at
> org.eclipse.emf.teneo.annotations.parser.EAnnotationParserImporter.processAnnotatedModelElement(EAnnotationParserImporter.java:149)
> at org.eclipse.emf.teneo.annotations.parser.EAnnotationParserImporter.process(EAnnotationParserImporter.java:65)
> at org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingBuilder.buildMapping(PersistenceMappingBuilder.java:171)
> at org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingBuilder.buildMapping(PersistenceMappingBuilder.java:88)
> at org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingBuilder.buildMapping(PersistenceMappingBuilder.java:80)
> at org.eclipse.emf.teneo.hibernate.mapper.MappingUtil.generateMapping(MappingUtil.java:81)
> at org.eclipse.emf.cdo.server.hibernate.teneo.CDOMappingGenerator.generateMapping(CDOMappingGenerator.java:117)
> at
> org.eclipse.emf.cdo.server.hibernate.internal.teneo.TeneoHibernateMappingProvider.generateMapping(TeneoHibernateMappingProvider.java:146)
> at
> org.eclipse.emf.cdo.server.hibernate.internal.teneo.TeneoHibernateMappingProvider.getMapping(TeneoHibernateMappingProvider.java:76)
> at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore.initConfiguration(HibernateStore.java:520)
> at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore.getHibernateSessionFactory(HibernateStore.java:256)
> at
> org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.beginHibernateSession(HibernateStoreAccessor.java:194)
> at
> org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.getNewHibernateSession(HibernateStoreAccessor.java:291)
> at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.doWrite(HibernateStoreAccessor.java:661)
> at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:149)
> at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:487)
> at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:43)
> at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
> at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:262)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:96)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:86)
> at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:92)
> at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
> at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:65)
> at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
> at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
> at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
> at java.lang.Thread.run(Thread.java:680)
> Any idea what could be the problem?
> Thanks
> Kris
> Am 02.02.13 15:32, schrieb KW:
>> Should work like described here:
>> http://stackoverflow.com/questions/9384813/can-i-reuse-ecore-models-by-importing-them-into-other-models
>> In the Load Resource Pop-Up I chose "Browse Registered Packages" and
>> then "http://www.eclipse.org/emf/CDO/Etypes/4.0.0" and let the default
>> option "Development Time Version" instead of "Runtime Version".
>> Is the "Development Time Version" option correct?
>> Thanks
>> Kris
>> Am 02.02.13 15:10, schrieb KW:
>>> Hello Eike,
>>> thanks! At first sight of LobTest I thought it is CDO DB Store specific
>>> and I have to search for another solution when using hibernate store.
>>> Apparently, it is not.
>>> Is there any further info on how to load the etypes.ecore into the
>>> model, as mentioned in
>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=284307 -> Comment 16?
>>> Thanks
>>> Kris
>>> Am 02.02.13 13:30, schrieb Eike Stepper:
>>>> Am 02.02.2013 13:02, schrieb KW:
>>>>> Hi,
>>>>> I am currently struggling with the problem that I do not know how to
>>>>> write / read a LOB typed attribute of an Ecore model into the DB as
>>>>> stream (to prevent OutOfMemory errors - want to save files in the db).
>>>>> I defined the Ecore model like described in the Teneo Wiki:
>>>>> http://wiki.eclipse.org/Teneo/Hibernate/ModelRelational/Teneo_Annotation_Examples
>>>>> --> Lob Annotation
>>>>> Furthermore the wiki tells how to create a java.sql.Blob with a
>>>>> Hibernate method which doesn't seem to be available any more.
>>>>> Blob blob = Hibernate.createBlob(new byte[] { 1, 2, 3, 4 });
>>>>> It seems that a Hibernate Session is needed for creating a Blob:
>>>>> LobHelper myLobHelper = org.hibernate.Session.getLobHelper
>>>>> Blob myBlob = myLobHelper.createBlob(InputStream stream,
>>>>> long length)
>>>>> Is there a way to get the underlying hibernate session to accomplish
>>>>> this?
>>>>> Is this the correct approach anyhow to to write / read LOBs
>>>>> stream-based to/from the DB?
>>>> Why do you mention the DB? Are you trying to do things on the server
>>>> side?
>>>> Normally you would just interface the model API on the client side. Some
>>>> usage examples are in LobTest:
>>>> http://git.eclipse.org/c/cdo/cdo.git/tree/plugins/org.eclipse.emf.cdo.tests/src/org/eclipse/emf/cdo/tests/LobTest.java
>>>> Cheers
>>>> /Eike
>>>> http://thegordian.blogspot.com
>>>> http://twitter.com/eikestepper
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006938 is a reply to message #1006829] Sun, 03 February 2013 00:21 Go to previous messageGo to next message
Am 02.02.2013 15:32, schrieb KW:
> In the Load Resource Pop-Up I chose "Browse Registered Packages" and then
> "http://www.eclipse.org/emf/CDO/Etypes/4.0.0" and let the default option "Development Time Version" instead of
> "Runtime Version".
I didn't know that these options exist. When I try "Development Time Version" I still end up with a
"platform:/plugin/..." URI, while I expected to see a "platform:/resource/..." URI. Perhaps Ed can comment on the
rationale of these options.
I usually import the containing plugin into the workspace and then load the desired model from there.
Cheers
/Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006941 is a reply to message #1006840] Sun, 03 February 2013 00:15 Go to previous messageGo to next message
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006942 is a reply to message #1006829] Sun, 03 February 2013 00:21 Go to previous messageGo to next message
> "Runtime Version".
Cheers
/Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006945 is a reply to message #1006840] Sun, 03 February 2013 00:15 Go to previous messageGo to next message
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006946 is a reply to message #1006829] Sun, 03 February 2013 00:21 Go to previous messageGo to next message
> "Runtime Version".
Cheers
/Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006949 is a reply to message #1006840] Sun, 03 February 2013 00:15 Go to previous messageGo to next message
Cheers
/Eike
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Kris
>> Thanks
>> Kris
>>> Hello Eike,
>>> Thanks
>>> Kris
>>>>> Hi,
>>>>> --> Lob Annotation
>>>>> long length)
>>>>> this?
>>>> side?
>>>> Cheers
>>>> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006950 is a reply to message #1006829] Sun, 03 February 2013 00:21 Go to previous messageGo to next message
> "Runtime Version".
Cheers
/Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006953 is a reply to message #1006829] Sun, 03 February 2013 00:21 Go to previous messageGo to next message
> "Runtime Version".
Cheers
/Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006954 is a reply to message #1006870] Sun, 03 February 2013 02:04 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Eike,
No, I'd expect that to yield a platform:/plugin URI (that references the
serialized model in the bundle). The Target Platform Version is a
better option in recent builds; it resolves to bundle in the target
platform rather than in the running IDE and uses platform:/resource
(because all target platform bundles are, via URI mapping, made to
appear as if they are projects in the workspace).
>> default option "Development Time Version" instead of "Runtime Version".
> Version" I still end up with a "platform:/plugin/..." URI, while I
> on the rationale of these options.
> Cheers
> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006955 is a reply to message #1006870] Sun, 03 February 2013 02:04 Go to previous messageGo to next message
Eike,
> Cheers
> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006956 is a reply to message #1006870] Sun, 03 February 2013 02:04 Go to previous messageGo to next message
Eike,
> Cheers
> /Eike
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1006977 is a reply to message #1006867] Sun, 03 February 2013 08:27 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Kris,
It seems that the Lob annotation is on the EPackage, it should be on the efeature storing the lob. But... for CDO/Teneo
you don't need to set the @Lob annotation. You don't need to use the Hibernate Lob either.
To work with blob/clob you should use the CDO Blob/CLOb types from the CDO ETypes epackage. Teneo will automatically
take care of mapping them as lobs.
gr. Martin
> Cheers
> /Eike
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks
>> Kris
>>> Thanks
>>> Kris
>>>> Hello Eike,
>>>> Thanks
>>>> Kris
>>>>>> Hi,
>>>>>> --> Lob Annotation
>>>>>> long length)
>>>>>> this?
>>>>> side?
>>>>> Cheers
>>>>> /Eike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [CDO][Teneo] How to write / read LOB data stream based? [message #1007191 is a reply to message #1006977] Mon, 04 February 2013 16:27 Go to previous message
Kris Missing name is currently offline Kris Missing name
Member
Hooray - it works now!
I don't know why the annation went up to package level - I assume it
happened accidentaly when I was referencin the cdo etypes types via
"Load Resource".
Thank you Eike / Ed / Martin!
Am 03.02.13 14:27, schrieb Martin Taal:
> Hi Kris,
> efeature storing the lob. But... for CDO/Teneo you don't need to set the
> CDO ETypes epackage. Teneo will automatically take care of mapping them
> as lobs.
> gr. Martin
>>> The eclass:
>> Cheers
>> /Eike
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thanks
>>> Kris
>>>> Thanks
>>>> Kris
>>>>> Hello Eike,
>>>>> specific
>>>>> Thanks
>>>>> Kris
>>>>>>> Hi,
>>>>>>> db).
>>>>>>> --> Lob Annotation
>>>>>>> long length)
>>>>>>> this?
>>>>>> side?
>>>>>> side. Some
>>>>>> Cheers
>>>>>> /Eike
Previous Topic:Copy EObject with eOpposite refs
Next Topic:[CDO] and eAdapters
Current Time: Tue May 21 03:28:12 EDT 2013
Powered by FUDForum. Page generated in 0.03659 seconds
