Home » Eclipse Projects » Eclipse Process Manager (Stardust) » cp1252 encoding exception during Tomcat6 server startup on Windows
cp1252 encoding exception during Tomcat6 server startup on Windows [message #1006580] Thu, 31 January 2013 16:56 Go to next message
Jan Hendrik Scheufen is currently offline Jan Hendrik Scheufen
Member
I've deployed a Stardust 0.7 Spring WAR on Tomcat 6 and the application seems to startup fine (according to the log), but then it shuts itself down immediately. There's nothing in the stardust log, but I'm getting the following stacktrace in the catalina.log of the server.
INFO: Starting Servlet Engine: Apache Tomcat/6.0.36
Jan 31, 2013 4:49:35 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor ipp-portal.xml
Jan 31, 2013 4:49:36 PM org.apache.catalina.core.StandardContext addApplicationListener
INFO: The listener "com.icesoft.faces.util.event.servlet.ContextEventRepeater" is already configured for this context. The duplicate definition has been ignored.
INFO: The listener "org.apache.myfaces.webapp.StartupServletContextListener" is already configured for this context. The duplicate definition has been ignored.
Jan 31, 2013 4:49:57 PM com.sun.xml.ws.transport.http.servlet.WSServletContextListener contextInitialized
INFO: WSSERVLET12: JAX-WS context listener initializing
Jan 31, 2013 4:50:04 PM com.sun.xml.wss.jaxws.impl.SecurityServerTube configureServerHandler
SEVERE: WSSTUBE0027: Error in configuring Server Security Callback Handler.
java.lang.RuntimeException: org.xml.sax.SAXParseException: Invalid encoding name "cp1252".
	at com.sun.xml.wss.impl.misc.DefaultRealmAuthenticationAdapter.populateTomcatUsersXML(DefaultRealmAuthenticationAdapter.java:275)
	at com.sun.xml.wss.impl.misc.DefaultRealmAuthenticationAdapter.<init>(DefaultRealmAuthenticationAdapter.java:96)
	at com.sun.xml.wss.RealmAuthenticationAdapter.newInstance(RealmAuthenticationAdapter.java:147)
	at com.sun.xml.wss.jaxws.impl.SecurityServerTube.getRealmAuthenticationAdapter(SecurityServerTube.java:767)
	at com.sun.xml.wss.jaxws.impl.SecurityServerTube.configureServerHandler(SecurityServerTube.java:733)
	at com.sun.xml.wss.jaxws.impl.SecurityServerTube.<init>(SecurityServerTube.java:150)
	at com.sun.xml.wss.provider.wsit.SecurityTubeAppender.appendTube(SecurityTubeAppender.java:129)
	at com.sun.xml.ws.assembler.TubelineAssemblerFactoryImpl$WsitTubelineAssembler.createServer(TubelineAssemblerFactoryImpl.java:101)
	at com.sun.xml.ws.server.WSEndpointImpl.<init>(WSEndpointImpl.java:152)
	at com.sun.xml.ws.server.EndpointFactory.createEndpoint(EndpointFactory.java:218)
	at com.sun.xml.ws.api.server.WSEndpoint.create(WSEndpoint.java:467)
	at com.sun.xml.ws.transport.http.DeploymentDescriptorParser.parseAdapters(DeploymentDescriptorParser.java:253)
	at com.sun.xml.ws.transport.http.DeploymentDescriptorParser.parse(DeploymentDescriptorParser.java:147)
	at com.sun.xml.ws.transport.http.servlet.WSServletContextListener.contextInitialized(WSServletContextListener.java:108)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4206)
	at org.apache.catalina.core.StandardContext.start(StandardContext.java:4705)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:799)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:779)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:601)
	at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:675)
	at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:601)
	at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:502)
	at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1317)
	at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:324)
	at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:142)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1065)
	at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1057)
	at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
	at org.apache.catalina.core.StandardService.start(StandardService.java:525)
	at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
	at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
	at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
Caused by: org.xml.sax.SAXParseException: Invalid encoding name "cp1252".
	at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
	at org.apache.xerces.jaxp.DocumentBuilderImpl.parse(Unknown Source)
	at javax.xml.parsers.DocumentBuilder.parse(Unknown Source)
	at com.sun.xml.wss.impl.misc.DefaultRealmAuthenticationAdapter.populateTomcatUsersXML(DefaultRealmAuthenticationAdapter.java:254)
	... 37 more
Re: cp1252 encoding exception during Tomcat6 server startup on Windows [message #1007179 is a reply to message #1006580] Mon, 04 February 2013 14:01 Go to previous message
Member
The problem in this case came from one of the files installed by Tomcat itself. The "tomcat-users.xml" file was the only one which had a "cp1252" encoding in the XML prolog.
Changing it to "UTF-8" solved the problem. (Usually you'd make sure the file is really UTF-8 encoded by opening it in an appropriate text editor, but here the file is not really used anyways ...).
Jan
Previous Topic:Custom ESB application type
Next Topic:Starting and reactivating multiple process instances
Current Time: Sat May 25 06:24:35 EDT 2013
Powered by FUDForum. Page generated in 0.01461 seconds
