| org.eclipse.emf.mwe.utils.Reader is not working [message #1007074] |
Mon, 04 February 2013 05:52  |
Prodipta Mondal Messages: 8 Registered: January 2013 |
Junior Member |
Hi ,
I am trying to read .emx file using normal mwe workflow.I am not able to figure out why it's getting the stereoTyped elements of the model.Please find the complete workflow below.I am also attaching the model and profile which I am trying to generate.
<?xml version="1.0"?>
<workflow>
<!--Store Global Vars-->
<component class="com.accn.oaw.component.common.StoreGlobalVars" skipOnErrors="true">
<globalVarDef name="target_workspace" value="${target_workspace}"/>
<globalVarDef name="project_name" value="${project_name}"/>
<globalVarDef name="package_prefix" value="${package_prefix}"/>
</component>
<component class="com.accn.oaw.component.common.RSASetup">
<extensionMap from="efx" to="org.eclipse.uml2.uml.resource.UMLResource" />
<init value="true" />
</component>
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<registerGeneratedEPackage value="org.eclipse.gmf.runtime.notation.NotationPackage"/>
<registerGeneratedEPackage value="com.ibm.xtools.umlnotation.UmlnotationPackage"/>
<platformUri value="${model_workspace}"/>
</bean>
<component id="read" class="org.eclipse.emf.mwe.utils.Reader">
<uri value="${inputmodel.file}"/>
<modelSlot value="model"/>
</component>
<bean class="org.eclipse.xtend.typesystem.emf.EmfMetaModel" id="metaModelId">
<metaModelFile value="com/accn/ecoremetamodel/common/MetaModel.ecore"/>
</bean>
<!-- transform model -->
<component class="org.eclipse.xtend.XtendComponent">
<metaModel class="org.eclipse.xtend.typesystem.uml2.profile.ProfileMetaModel">
<profile value="com/accn/ecoremetamodel/common/Profile.profile.uml"/>
</metaModel>
<invoke value="com::accn::oaw::m2m::common::Transform::transformModel(model)"/>
<outputSlot value="transformedModel"/>
</component>
<!-- Generate Code -->
<component class="org.eclipse.xpand2.Generator">
<metaModel idRef="metaModelId"/>
<metaModel class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
<expand value="com::accn::expand::atomicservices::TemplateACS::root FOR transformedModel"/>
<outlet path="${target_workspace}"/>
<beautifier class="org.eclipse.xpand2.output.JavaBeautifier" configFile="CodeFormatter.xml"/>
</component>
</workflow>
Any suggestion would be appreciated.Thanks in advance.
[Updated on: Mon, 04 February 2013 05:52] Report message to a moderator
| Re: org.eclipse.emf.mwe.utils.Reader is not working [message #1007097 is a reply to message #1007074] |
Mon, 04 February 2013 07:44  |
Ed Willink Messages: 3191 Registered: July 2009 |
I am not aware of what Eclipse support there is for *.emx, so I can only
redirect your question to your *.emx source and/or the MWE tooling (on
the EMF newsgroup).
Ed Willink
On 04/02/2013 10:52, Prodipta Mondal wrote:
> Hi ,
> <workflow>
> </component> <component class="com.accn.oaw.component.common.RSASetup">
> to="org.eclipse.uml2.uml.resource.UMLResource" /> <init value="true" />
> </component> <bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
> value="com.ibm.xtools.umlnotation.UmlnotationPackage"/> <platformUri
> value="${model_workspace}"/> </bean>
> </component> <bean
> </bean>
> <metaModel
> </metaModel>
> <invoke
> <outputSlot value="transformedModel"/> </component> <!-- Generate Code
> <metaModel
> </component> </workflow>
FUDForum. Page generated in 0.01517 seconds
