Home » Modeling » EMF » EcoreUtil.copyAll and EMap
EcoreUtil.copyAll and EMap [message #1007038] Mon, 04 February 2013 03:26 Go to next message
Martin Taal is currently offline Martin Taal
I have a model with an emap where the value is a non-containment ereference. It seems that EcoreUtil.copyAll does not
correctly copy the value of the emap elements (it is null). Is this a known issue?
If not then I can create a bugzilla (with a testcase) to show the problem.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: EcoreUtil.copyAll and EMap [message #1007045 is a reply to message #1007038] Mon, 04 February 2013 03:38 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Martin,
The Copier is not aware of EMaps. From that perspective an EMap is just
a containment reference to the EObjects that represent the Map.Entry
instances. So the value reference of the map entry will be copied
during copyReferences just like any other cross reference. The only
thing that would prevent copying is if it's a bidirectional reference
and the referenced object itself has not been copied...
So try setting a breakpoint (conditional on the reference's name being
"value") in
org.eclipse.emf.ecore.util.EcoreUtil.Copier.copyReference(EReference,
EObject, EObject) and see why its not copying the reference...
On 04/02/2013 9:26 AM, Martin Taal wrote:
> ereference. It seems that EcoreUtil.copyAll does not correctly copy
> problem.
Re: EcoreUtil.copyAll and EMap [message #1007064 is a reply to message #1007045] Mon, 04 February 2013 05:10 Go to previous message
Hi Ed,
Ouch, it was a problem in my code, so this post can be forgotten...
gr. Martin
On 02/04/2013 09:38 AM, Ed Merks wrote:
> Martin,
> The Copier is not aware of EMaps. From that perspective an EMap is just a containment reference to the EObjects that
> represent the Map.Entry instances. So the value reference of the map entry will be copied during copyReferences just
> like any other cross reference. The only thing that would prevent copying is if it's a bidirectional reference and the
> So try setting a breakpoint (conditional on the reference's name being "value") in
> org.eclipse.emf.ecore.util.EcoreUtil.Copier.copyReference(EReference, EObject, EObject) and see why its not copying the
> reference...
The Netherlands
Previous Topic:[CDO] Problem with package on CDO M4, but not on M3
Next Topic:[Teneo] QuickStart Tutorial fails to create tables
Current Time: Sat May 25 06:04:18 EDT 2013
Powered by FUDForum. Page generated in 0.01647 seconds
