Home » Eclipse Projects » Koneki » How to remote debug
How to remote debug [message #1006982] Sun, 03 February 2013 09:56 Go to next message
Master King is currently offline Master King
I followed the LDT user guide, but I found some steps were broken.I used mac os and ldt 0,9.
In http://wiki.eclipse.org/Koneki/LDT/Debugger to install debugger. In section Linux ( OSX compatible ), it says "Edit run script", but I couldn't find it in Media:Debugger_lua.zip. And it used command line lua to debug, do I need switch to command line?
And in below topic how to debug like the tool "decoda"?
it said: requirement) the lua global variable "package.path" in the lua must contains a path to luasocket libraries/binaries.
but I already installed luasocket in above steps.
I'm confused by these. please help. thx.
Re: How to remote debug [message #1007315 is a reply to message #1006982] Tue, 05 February 2013 08:54 Go to previous message
Marc Aubry is currently offline Marc Aubry
Member
Hi Master King,
First, thanks for asking.
Unfortunately, the wiki page you follow is obsolete, so instead, please refer to the user guide of the 0.9.
http://wiki.eclipse.org/Koneki/LDT/Developer_Area/User_Guides/User_Guide_0.9#Debug
I have added disclaimers at the top obsolete pages to avoid future misleading.
Marc
Previous Topic:Make .xml files to highlight the code
Next Topic:io.read waits before any print() output?
Current Time: Fri May 24 11:12:14 EDT 2013
Powered by FUDForum. Page generated in 0.01571 seconds
