Home » Modeling » Papyrus » Documenting UML elements in Papyrus(There's no way to document a class, an operation etc.)
Documenting UML elements in Papyrus [message #695908] Tue, 12 July 2011 15:53 Go to next message
Jay Billings is currently offline Jay Billings
Member
I was working with Papyrus in Helios the other day and I could not find a way to document a UML element. So, for example, if you click on a class in a diagram, all sorts of properties are displayed, but there is no where that I could type a description of that class. Another pertinent example would be an operation on a class - what if I want to add some documentation to just that operation and not the rest of the class?
Am I missing something critical here?
I could accomplish this using a note, but the result is a diagram full of notes and I can't access the documentation in a transformation to code.
Jay Jay Billings
Oak Ridge National Laboratory
Twitter: @jayjaybillings
Re: Documenting UML elements in Papyrus [message #696084 is a reply to message #695908] Wed, 13 July 2011 04:35 Go to previous messageGo to next message
Vincent   is currently offline Vincent
Member
Or you could ... use the "Documentation" view.
This view isn't in the default perspective, so you must add it with "Window>Show View" menu.
Use the "Comments" tab to add or display a UML Comment.
After that, you can still grab and drop the Comment if you want to display it in the diagram, but I must confess I couldn't find a way to graphically link it to the label.
Re: Documenting UML elements in Papyrus [message #696144 is a reply to message #696084] Wed, 13 July 2011 07:04 Go to previous messageGo to next message
Member
Thanks Vincent. I will take a look at the documentation view.
Jay Jay Billings
Re: Documenting UML elements in Papyrus [message #946859 is a reply to message #696084] Tue, 16 October 2012 11:13 Go to previous messageGo to next message
Keith Dorking is currently offline Keith Dorking
In the latest version of Papyrus v0.9.1 is the Documentation view still available?
Re: Documenting UML elements in Papyrus [message #946955 is a reply to message #946859] Tue, 16 October 2012 13:15 Go to previous messageGo to next message
Christian W. Damus is currently offline Christian W. Damus
Hi, Keith,
It should be. Do you not see it in the Show View dialog?
Christian
> available?
Re: Documenting UML elements in Papyrus [message #947773 is a reply to message #946955] Wed, 17 October 2012 08:20 Go to previous messageGo to next message
Hi Christian,
No unfortunately I do not see "Documentation" in the Show View dialog.. I have uploaded a screen capture of what I do see in the Show View dialog.
Keith
Re: Documenting UML elements in Papyrus [message #947980 is a reply to message #947773] Wed, 17 October 2012 12:29 Go to previous messageGo to next message
Hi, Keith,
This is the Show View menu, not the dialog.
What do you see when you choose the "Other..." option to open the Show
View dialog?
If you don't see the Documentation view in there, then you might check
the workspace log for any messages indicating that there's something
wrong with that view contribution, or that the plug-in that contributes
it has unresolved dependencies, or something.
HTH,
Christian
On 2012-10-17 12:20:29 +0000, Keith Dorking said:
> Hi Christian,
> dialog.
> Cheers,
> Keith
> <image>
Re: Documenting UML elements in Papyrus [message #948214 is a reply to message #947980] Wed, 17 October 2012 17:38 Go to previous messageGo to next message
Hi Christian,
Turns out that the Documentation view does not appear when Papyrus is installed with eclipse 4.2 (Juno), but it is there when Papyrus is installed with eclipse 3.7 (Indigo).
Keith
[Updated on: Wed, 17 October 2012 19:18]
Report message to a moderator
Re: Documenting UML elements in Papyrus [message #997326 is a reply to message #948214] Sat, 05 January 2013 18:32 Go to previous messageGo to next message
Alexandre Kozlov is currently offline Alexandre Kozlov
It seems that the the following plugins are missing from the 0.9x
org.eclipse.papyrus.documentation.uml
org.eclipse.papyrus.documentation.view.papyrus
Re: Documenting UML elements in Papyrus [message #1006828 is a reply to message #997326] Sat, 02 February 2013 09:32 Go to previous messageGo to next message
alex lauter is currently offline alex lauter
Alexandre Kozlov wrote on Sat, 05 January 2013 18:32
Where do I get the above files?
Re: Documenting UML elements in Papyrus [message #1007056 is a reply to message #1006828] Mon, 04 February 2013 04:28 Go to previous message
Camille Letavernier is currently offline Camille Letavernier
The only way is to manually checkout the sources from the Papyrus SVN repository. These plug-ins are not shipped with Papyrus anymore. They should be replaced with a newer version in Papyrus 0.10/Kepler (June 2013).
SVN repository: http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/branches/0.9.X
Previous Topic:State diagram
Next Topic:[sysml] refine and derive dependencies
Current Time: Thu May 23 21:23:35 EDT 2013
Powered by FUDForum. Page generated in 0.08286 seconds
