Home » Eclipse Projects » BIRT » Carbon Copy
Carbon Copy [message #1006251] Wed, 30 January 2013 10:17 Go to next message
Paulo Mising name is currently offline Paulo Mising name
Hello Fellows,
I have a certain report and I get this int var value the number of copies that i'm suppose to do in one print at the time.
I would like to do carbon copies in just ONE print labeling them as "Original" , "Fist copy", and so on. the Original might get more that one page off course !!
Can any of you give me any sort on inspiration to do the job...please.
Thanks in advance
Re: Carbon Copy [message #1006285 is a reply to message #1006251] Wed, 30 January 2013 12:02 Go to previous messageGo to next message
Michael Williams is currently offline Michael Williams
I'm not sure I'm totally understanding the goal, but if I am, one thing you could do would be to use java to run your report with separate run and render tasks. Then, you'd just run the render task the number of times that your int variable says to and change a label within your report for each render. Hope this helps.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Carbon Copy [message #1006292 is a reply to message #1006285] Wed, 30 January 2013 12:21 Go to previous messageGo to next message
Ok you understand the question.
Can I do it with java scipt ?
Can I do it in the frameset ?
Thank you very much
Re: Carbon Copy [message #1006318 is a reply to message #1006292] Wed, 30 January 2013 14:31 Go to previous messageGo to next message
For the suggestion I had above, you're probably looking at using java. See this: Eclipse Wiki - Separate Run and Render (BIRT)
You could probably design a report that repeated the report contents x number of times based on your input int value, if you wanted to avoid java.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Carbon Copy [message #1006519 is a reply to message #1006318] Thu, 31 January 2013 09:56 Go to previous messageGo to next message
Hello Michael, how can i do repeat content by design, because i'm using the frameset servlet ?
Thank you
Paulo
Re: Carbon Copy [message #1006772 is a reply to message #1006519] Fri, 01 February 2013 13:36 Go to previous message
It appears that Kris is working on a javascript solution for you, over on BIRT Exchange. I'll just point this thread to that, for when he posts it.
BIRT Exchange Forum - Carbon Copy BIRT with Frameset
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic: There is no report design object available. exception with birt 3.7.2
Next Topic:How to add an editable text field ?
Current Time: Wed May 22 17:17:50 EDT 2013
Powered by FUDForum. Page generated in 0.01868 seconds
