Home » Eclipse Projects » WindowBuilder » Cannot add selectionHandler
Cannot add selectionHandler [message #1006753] Fri, 01 February 2013 11:47
John Rellis is currently offline John Rellis
I am creating an SWT/JFace application, the application was working fine last week.
Now I started up eclipse, copied the project and I am seeing some very strange behaviour, the first of which is i cannot add a selectionHandler to a menu item, I get a null pointer exception.
I have attached screens and the bug report. I hope this is a simple configuration issue. If anyone could help that would be great!
Internal Error
WindowBuilder encountered unexpected internal error.
This could be caused by a WindowBuilder bug or by a misconfiguration issue, conflict, partial update, etc.
Show stack trace.
Hide stack trace.
Stack trace:
	at org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(JavaElement.java:540)
	at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:255)
	at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:241)
	at org.eclipse.jdt.internal.core.JavaElement.exists(JavaElement.java:159)
	at org.eclipse.wb.internal.core.utils.jdt.core.CodeUtils.getResolvedTypeName_resolveTypeVariable(CodeUtils.java:659)
	at org.eclipse.wb.internal.core.utils.jdt.core.CodeUtils.getResolvedTypeName(CodeUtils.java:647)
	at org.eclipse.wb.internal.core.utils.jdt.core.CodeUtils.getMethodSignature(CodeUtils.java:609)
	at org.eclipse.wb.internal.core.utils.jdt.core.CodeUtils.findMethodSingleType(CodeUtils.java:541)
	at org.eclipse.wb.internal.core.utils.jdt.core.CodeUtils.findMethod(CodeUtils.java:503)
	at org.eclipse.wb.internal.core.model.property.event.ListenerMethodProperty.addListenerMethod(ListenerMethodProperty.java:577)
	at org.eclipse.wb.internal.core.model.property.event.ListenerMethodProperty.ensureListenerMethod(ListenerMethodProperty.java:536)
index.php/fa/13263/0/
index.php/fa/13264/0/
John
Previous Topic:Plzz Help me
Next Topic:WindowBuilder needs confirmation of JOptionPane.showMessageDialog
Current Time: Fri May 24 05:25:20 EDT 2013
Powered by FUDForum. Page generated in 0.01427 seconds
