Home » Modeling » Papyrus » StateMachine local vs. external transition
| StateMachine local vs. external transition [message #1006568] |
Thu, 31 January 2013 14:42  |
Andrea Sindico Messages: 250 Registered: November 2010 |
According to the UML specification (2.5 b1 pag. 377)
A transition may be one of these three kinds:
internal
Implies that the Transition, if triggered, occurs without exiting or entering the source State (i.e., it does not cause a state change). This means that the entry or exit condition of the source State will not be invoked. An internal Transition can be taken even if the SateMachine is in one or more Regions nested within the associated State.
local
Implies that the Transition, if triggered, will not exit the composite (source) State, but it will exit and re-enter any state within the composite State that is in the current state configuration.
external
Implies that the Transition, if triggered, will exit the composite (source) State.
As far as I understand, the internal basically implies the execution of an Action within the source state when certain condition occurs. Am I right?
the external is the transition that actually corresponds to a change from the source state to the target state.
I can't really see the meaning of the local transition explanation. May someone please provide a simple example helping me to get it?
Follow me on Twitter @andreasindico
[Updated on: Thu, 31 January 2013 14:45] Report message to a moderator
| Re: StateMachine local vs. external transition [message #1006639 is a reply to message #1006568] |
Fri, 01 February 2013 05:00   |
Klaas Gadeyne Messages: 36 Registered: July 2009 |
Member |
Andrea Sindico wrote on Thu, 31 January 2013 14:42According to the UML specification (2.5 b1 pag. 377)
internal
local
external
As far as I remember, the difference is that, in the case of a "local" transition, both "exit" and "entry" actions of the state will be executed. In the case of an internal one, they will not be executed (only the action specified on the transition itself will be executed.
| Re: StateMachine local vs. external transition [message #1006845 is a reply to message #1006639] |
Sat, 02 February 2013 14:47   |
Andrea,
please have also a look in the more elaborated (simlified?) UML 2.5 spec at
http://www.omg.org/spec/UML/2.5/Beta1/, section 14.2.3 and 14.2.4,
especially Figure 14.32 Local Transitions.
In short, a local transition does not exit a composite state and, thus,
never executed the exit behavior of the composite state. Local transitions
are only valid in composite states, where source and target Vertex are
different.
Marc-Florian
"Klaas Gadeyne" schrieb im Newsbeitrag
news:keg3n4$8a9$1@xxxxxxxxe.org...
> internal
> local
> external
> (source) State.
> Regards
| Re: StateMachine local vs. external transition [message #1007305 is a reply to message #1006847] |
Tue, 05 February 2013 08:22  |
Member |
Andrea Sindico wrote on Sat, 02 February 2013 15:22Hi Marc-Florian and Klaas,
I posted the same question here so that you can see the pictures of two state machines and tell me whether I have understood it or not.
http://stackoverflow.com/questions/14666095/uml-state-machines-local-vs-external-transition
thank you very much!
I think the answer is: "It depends". If there are no exit behaviours defined in the different states (and no other triggers on the transitions, etc.) , I think (at first sight) that the behaviour of the 2 machines will be equivalent [*]. As soon as the states have exit behaviours (but you didn't display them on the diagram), they are different IMO.
(that said, I am _not_ a UML FSM expert...)
HTH,
Klaas
[*] Maybe there are also some differences wrt the run-to-completion behaviour, but I haven't looked at it close enough for that.
Current Time: Mon May 20 04:45:41 EDT 2013
Powered by FUDForum. Page generated in 0.02207 seconds
