Home » Eclipse Projects » Buckminster » Not able to send email after build runs..
Not able to send email after build runs.. [message #1000180] Mon, 14 January 2013 02:50 Go to next message
Pankaj Singh is currently offline Pankaj Singh
I m using the hudson and i want to send email when particular event like build failure,success occur then a email notification could be sent. But when i check that if configuaration i have made is right or not by sending email then it is giving the error following..
pls suggest..
Failed to send out e-mail
com.sun.mail.smtp.SMTPSendFailedException: 530 5.7.0 Must issue a STARTTLS command first. d1sm8285663pav.6
at com.sun.mail.smtp.SMTPTransport.issueSendCommand(SMTPTransport.java:2057)
at com.sun.mail.smtp.SMTPTransport.mailFrom(SMTPTransport.java:1580)
at com.sun.mail.smtp.SMTPTransport.sendMessage(SMTPTransport.java:1097)
at hudson.tasks.Mailer$DescriptorImpl.send(Mailer.java:507)
at hudson.tasks.Mailer$DescriptorImpl.doSendTestMail(Mailer.java:461)
at org.kohsuke.stapler.Function$InstanceFunction.invoke(Function.java:274)
at org.kohsuke.stapler.Function.bindAndInvoke(Function.java:141)
at org.kohsuke.stapler.Function.bindAndInvokeAndServeResponse(Function.java:80)
at org.kohsuke.stapler.MetaClass$1.doDispatch(MetaClass.java:95)
at org.kohsuke.stapler.NameBasedDispatcher.dispatch(NameBasedDispatcher.java:45)
at org.kohsuke.stapler.Stapler.tryInvoke(Stapler.java:565)
at org.kohsuke.stapler.Stapler.invoke(Stapler.java:650)
at org.kohsuke.stapler.MetaClass$12.dispatch(MetaClass.java:365)
at org.kohsuke.stapler.MetaClass$4.doDispatch(MetaClass.java:187)
at org.kohsuke.stapler.Stapler.invoke(Stapler.java:481)
at org.kohsuke.stapler.Stapler.service(Stapler.java:152)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:648)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1336)
at hudson.util.PluginServletFilter$1.doFilter(PluginServletFilter.java:86)
at org.hudsonci.servlets.internal.ServletRegistrationFilterAdapter.doFilter(ServletRegistrationFilterAdapter.java:162)
at org.hudsonci.servlets.internal.ServletRegistrationFilterAdapter.doFilter(ServletRegistrationFilterAdapter.java:134)
at hudson.util.PluginServletFilter$1.doFilter(PluginServletFilter.java:89)
at hudson.util.PluginServletFilter.doFilter(PluginServletFilter.java:78)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1307)
at hudson.security.ChainedServletFilter$1.doFilter(ChainedServletFilter.java:81)
at hudson.security.ChainedServletFilter.doFilter(ChainedServletFilter.java:73)
at hudson.security.HudsonFilter.doFilter(HudsonFilter.java:157)
at hudson.util.CharacterEncodingFilter.doFilter(CharacterEncodingFilter.java:70)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:453)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:534)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1072)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:382)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1006)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)
at org.eclipse.jetty.server.Server.handle(Server.java:365)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:485)
at org.eclipse.jetty.server.AbstractHttpConnection.content(AbstractHttpConnection.java:937)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.content(AbstractHttpConnection.java:998)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:856)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:240)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:627)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:51)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)
at java.lang.Thread.run(Unknown Source)
Re: Not able to send email after build runs.. [message #1006053 is a reply to message #1000180] Tue, 29 January 2013 11:07 Go to previous messageGo to next message
Matthew Webber is currently offline Matthew Webber
You should ask this in a Hudson forum (or Jenkins, if that is what you are using). This forum is for Buckminster.
Re: Not able to send email after build runs.. [message #1006621 is a reply to message #1000180] Fri, 01 February 2013 04:03 Go to previous message
Leon Qin is currently offline Leon Qin
I have the same problem in using the latest hudson.
After looked at its code, I found that is caused by a bug in the hudson mailer.
I compiled my version of hudson-core which contains the hudson mailer, then replaced the official version. Now email could work.
Let me know if you need my version. qinling.net[at]gmail.com
Previous Topic:Specifying a specific set of ws/os/arch for a p2 site
Next Topic:No suitable provider for component org.eclipse.rcp
Current Time: Tue May 28 23:34:21 EDT 2013
Powered by FUDForum. Page generated in 0.01808 seconds
