Home » Modeling » EMF » Utility to copy CDOObject data only(Utility to copy CDOObject data only)
Utility to copy CDOObject data only [message #1006582] Thu, 31 January 2013 17:08 Go to next message
Andrew Whelan is currently offline Andrew Whelan
Member
Lets say I have 2 CDObjects, object1 and object2.
Is there a CDOUtility
copy(object2, object1)
that will allow me to copy only the data elements of object1 into object2 but yet wont effect any of the CDO plumbing of object2(CDOID, CDOView, etc)? I'd like to keep the CDOTransaction and CDOSession of object2 intact. I just want to update its data with that of object1. I was wondering if this is something I need to write myself.
 object2 = EcoreUtil.copy(object1)
Will obviously hose all of the CDO plumbing.
-Andrew
Re: Utility to copy CDOObject data only [message #1006609 is a reply to message #1006582] Fri, 01 February 2013 02:17 Go to previous message
Eike Stepper is currently offline Eike Stepper
Am 31.01.2013 23:08, schrieb Andrew Whelan:
No, the copy of an object is always detached from the graph, which in CDO implies that it's TRANSIENT (i.e., view==null,
id==null).
> object1.
That's not possible, because the container reference is implicitely bidirectional and leaving it intact would imply to
add the object to the containment reference of its container.
Yes, only you can decide where to attach/add the copied object.
Yes, and the EMF plumbing (the container reference), too.
Cheers
/Eike
http://www.esc-net.de
Previous Topic:[CDO] CDOTransaction.close
Next Topic:[CDO] Installation of CDO 4.2 failed
Current Time: Sun May 19 08:57:57 EDT 2013
Powered by FUDForum. Page generated in 0.01742 seconds
