Home » Modeling » Papyrus » State diagram
State diagram [message #629479] Tue, 28 September 2010 08:50 Go to next message
Filippo  is currently offline Filippo
Hi everyone, i am tring to use papyrus for making my uml model. I had now to make some state diagram, but I have a problem: when i add any kind of action in a state befor the name of the action appear "OpaqueBehavior" and i wold like to remove it. How can I do that?
Re: State diagram [message #630264 is a reply to message #629479] Fri, 01 October 2010 07:16 Go to previous messageGo to next message
David Servat is currently offline David Servat
Thanks for the feedback!
Unfortunately there is no way for now to remove this mention of the type of behavior (Activity, SM, Opaque, etc.). This is not standard-compliant but was done for readability - if you have different behaviors with same name for instance - and test purposes. The next release of Papyrus in the coming weeks will have a more advanced State machine diagram support compared to the current one.
So bear with it for the moment and look for the next version when it is out!
Cheers
David
Re: State diagram [message #630323 is a reply to message #630264] Fri, 01 October 2010 11:16 Go to previous messageGo to next message
Sebastien Gerard is currently offline Sebastien Gerard
State machine diagram editor of Papyrus has been updated this week including allmost of required feature for drawing UML2 state machine.
Best... Sébastien.
Re: State diagram [message #1006555 is a reply to message #629479] Thu, 31 January 2013 12:22 Go to previous message
Alessandro Ranieri is currently offline Alessandro Ranieri
I resume this topic because I have a similar question. My problem is that when I write an opaqueBehavior , i.e. in a state, if it multi-line, I will visualize only the first line I write on the state machine graph.
Is there a way to visualize all the line?
Thanks in advance,
Alessandro R.
[Updated on: Thu, 31 January 2013 12:27]
Report message to a moderator
Previous Topic:Best Way to Import Existing UML model into Papyrus
Next Topic:Documenting UML elements in Papyrus
Current Time: Sun May 19 01:57:21 EDT 2013
Powered by FUDForum. Page generated in 0.01583 seconds
