Home » Eclipse Projects » BIRT » Persistent variables in BIRT scripts
Persistent variables in BIRT scripts [message #1006487] Thu, 31 January 2013 08:36 Go to next message
donino donino is currently offline donino donino
Member
I am not sure how to use correctly vars[]: with BIRT 4.2.1, i noticed when we create a new var in the "Variables" section, if we set it with some "onCreate" script:
vars["myVar"]="myValue"
Then in a "onRender" script, vars["myVar"] will not be defined, it does not look persistent. But if we set it like this in "onCreate":
reportContext.setPersistentGlobalVariable("myVar","myValue");
This time, in a "onRender" script, vars["myVar"] is equals to "myValue".
Since it is more friendly to drag and drop "myVar" from Variables section than writing reportContext.getPersistentGlobalVariable("myVar") in a render expression, i wonder if we can rely on this behavior:
When we add a new variable in "Variables" eclipse designer section, does "setPersistentGlobalVariable" refer to this variable, or is it just a side-effect (may be a bug) which could change in a future version?
Thanks!
[Updated on: Thu, 31 January 2013 08:38]
Report message to a moderator
Re: Persistent variables in BIRT scripts [message #1006537 is a reply to message #1006487] Thu, 31 January 2013 10:41 Go to previous messageGo to next message
Michael Williams is currently offline Michael Williams
I don't see the same issue recalling the vars["myVar"] if you set it like: vars["myVar"] = "myValue". Can you create a sample design showing the issue that I can run?
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Persistent variables in BIRT scripts [message #1006973 is a reply to message #1006537] Sun, 03 February 2013 06:43 Go to previous messageGo to next message
Member
Thank for your response Michael.
mmh your are right, finally i can't reproduce this issue neither Confused I probably drunk too much last week, sorry!
I did not find a tech-note or a post concerning these "Report Variables", can we rely on the fact they are persistent (can be used in a "render" event when they are initialized in a "run" event such onCreate)?
Thanks!
[Updated on: Sun, 03 February 2013 06:45]
Re: Persistent variables in BIRT scripts [message #1007022 is a reply to message #1006973] Mon, 04 February 2013 01:00 Go to previous message
Ha ha. That's quite alright! Yes, there should be no issues using report variables across events. Report and Page variables were introduced back in 2.5. Here is a look at the new and notable, from then.
New and Notable - BIRT 2.5
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:How to localize currency symbols in BIRT in the web application?
Next Topic:How to get the report "Layout preference" with engine API
Current Time: Sat May 25 23:51:50 EDT 2013
Powered by FUDForum. Page generated in 0.01626 seconds
