| JMerge error when merging annotations on EnumLiteral [message #1006459] |
Thu, 31 January 2013 05:40 |
Martin Taal Messages: 5054 Registered: July 2009 |
I am using (in Texo) jmerge to merge a generated source file with an existing one. It fails on an enum when merging a
generated source with an existing source. For me jmerge is a total blackbox.. :-(. So I hope someone can give some
guidance if the merge rules should be adapted to correctly support java annotations (on enum literals). Attached my
merge xml file which is the same as being used by EMF proper also.
Also attached the source file after merge with the error. The error is on line 24 where the name of the literal MYSTERY
is truncated to MYST.
I also attached the current source file and the generated code before merging.
I really hope someone can give me some guidance here...
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.01647 seconds
