Home » Eclipse Projects » BIRT » Dynamically Add Group To Table in BIRT
Dynamically Add Group To Table in BIRT [message #1006418] Thu, 31 January 2013 05:13 Go to next message
Paul Cockerill is currently offline Paul Cockerill
I want to GROUP my report based on a parameter selected by the user. I am able to drop the current group in BeforeFactory, however how can I pass the parameter selected by the user to update the value the data will be grouped by.
For example I will provide a parameter with the Values "AREA" and "SALESMAN". Depending on what's selected I would like the report to group by the selected data.
Thanks in advance
Paul
Re: Dynamically Add Group To Table in BIRT [message #1006770 is a reply to message #1006418] Fri, 01 February 2013 13:31 Go to previous messageGo to next message
Michael Williams is currently offline Michael Williams
Have you tried just using the expression builder, for the group field to change the grouping based on the parameter? Then, you could do something similar in a dynamic text for the group header.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Dynamically Add Group To Table in BIRT [message #1007367 is a reply to message #1006770] Tue, 05 February 2013 11:14 Go to previous messageGo to next message
Not been using BIRT for very long. I will give it a go and let you know how I get on.
Re: Dynamically Add Group To Table in BIRT [message #1007379 is a reply to message #1007367] Tue, 05 February 2013 11:41 Go to previous messageGo to next message
Ah. Well, let me know if you run into issues. If you give me your BIRT version, I can make an example.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Dynamically Add Group To Table in BIRT [message #1007383 is a reply to message #1007379] Tue, 05 February 2013 11:55 Go to previous messageGo to next message
Thanks. Version Number 2.5.2 Bit behind but our ERP supplier prefers this version for compatibility reasons.
Hopefully we will be able to upgrade when we install the next major release.
Paul
Re: Dynamically Add Group To Table in BIRT [message #1007399 is a reply to message #1006418] Tue, 05 February 2013 13:11 Go to previous messageGo to next message
Take a look at this example. Look at the expression for the grouping on the table. Also, look at the expression in the text box in the group header.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Dynamically Add Group To Table in BIRT [message #1009763 is a reply to message #1007399] Fri, 15 February 2013 11:57 Go to previous messageGo to next message
Thanks, just what i needed.
Paul
Re: Dynamically Add Group To Table in BIRT [message #1009879 is a reply to message #1009763] Fri, 15 February 2013 17:58 Go to previous message
Not a problem. Let us know whenever you've got questions!
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:chart Zooming
Next Topic:Change BIRT Logging level for specific class/package
Current Time: Fri May 24 16:19:04 EDT 2013
Powered by FUDForum. Page generated in 0.08689 seconds
