| CSS property 'unselected-tabs-color' has been deprecated [message #1006407] |
Thu, 31 January 2013 04:33  |
Oliver Kolling Messages: 21 Registered: April 2010 |
Junior Member |
I installed eclipse juno (see attached img) and created a simple Application.e4xmi file and worked on it with the model editor. When I run the product, it works fine so far, but it gives me the "deprecated"- messages below and I'm wondering if I missed something with the installation ?
Thanks.
!SESSION 2013-01-31 08:37:05.230 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_07
Framework arguments: -product test.product -clearPersistedState
Command-line arguments: -product test.product -data C:\test\workspace4x/../runtime-test.product -dev file:C:/test/workspace4x/.metadata/.plugins/org.eclipse.pde.core/test.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog -clearPersistedState
!ENTRY org.eclipse.e4.ui.css.core 4 0 2013-01-31 08:37:08.772
!MESSAGE CSS property 'tab-renderer' has been deprecated: renamed as swt-tab-renderer
!ENTRY org.eclipse.e4.ui.css.swt 4 0 2013-01-31 08:37:08.775
!MESSAGE platform-style URIs deprecated for referencing types: use bundleclass://<bundlename>/<typename>
!ENTRY org.eclipse.e4.ui.css.core 4 0 2013-01-31 08:37:08.785
!MESSAGE CSS property 'unselected-tabs-color' has been deprecated: renamed as swt-unselected-tabs-color
!ENTRY org.eclipse.e4.ui.css.core 4 0 2013-01-31 08:37:08.790
!MESSAGE CSS property 'outer-keyline-color' has been deprecated: renamed as swt-outer-keyline-color
!ENTRY org.eclipse.e4.ui.css.core 4 0 2013-01-31 08:37:08.791
!MESSAGE CSS property 'inner-keyline-color' has been deprecated: renamed as swt-swt-inner-keyline-color
!ENTRY org.eclipse.e4.ui.css.core 4 0 2013-01-31 08:37:08.794
!MESSAGE CSS property 'tab-outline' has been deprecated: renamed as swt-tab-outline
!ENTRY org.eclipse.e4.ui.css.core 4 0 2013-01-31 08:37:08.799
!MESSAGE CSS property 'shadow-visible' has been deprecated: renamed as swt-shadow-visible
| Re: CSS property 'unselected-tabs-color' has been deprecated [message #1006701 is a reply to message #1006671] |
Fri, 01 February 2013 08:42  |
Junior Member |
Well, actually I need both. I always run two development environments one for the development for customers, which goes with the releases - and another one for testing which is either integration or stable.
Actually I'm trying to migrate a Eclipse 3.x RCP with JPA to Eclipse Juno 4.2 Release 0.12 with tooling from download.eclipse.org/e4/updates/0.12
and I'm also testing Kepler and the tooling for e4 which I do not exactly know for Kepler which one is the best to combine.
This also goes for the JPA where there is now the move from EclipeLink to Gemini not to mention the tooling for JPA (Dali).
I actually find it a bit difficult to put together a environment that is reliable and future proof and has the maximum on tooling support for an RCP/JPA application on Eclipse 4.x.
FUDForum. Page generated in 0.06400 seconds
