Home » Eclipse Projects » Eclipse 4 » Memory leak in TrackableComputaionExt(Memory leak in TrackableComputaionExt)
Memory leak in TrackableComputaionExt [message #1006373] Thu, 31 January 2013 02:20 Go to next message
Panneer Selvam is currently offline Panneer Selvam
I have a form editor extended from eclipse Form editor. After closing the editor I still see that the editor instance is alive. I saw the following in YourKit memory snapshot
Is there any way how I can dispose this object?
activePart of org.eclipse.ui.internal.expressions.ActivePartExpression
expression of org.eclipse.ui.internal.contexts.ContextService$UpdateExpression
runnable of org.eclipse.e4.core.internal.contexts.TrackableComputationExt
key of java.util.HashMap$Entry
[233] of java.util.HashMap$Entry[256]
table of java.util.HashMap
map of java.util.HashSet
value of java.util.HashMap$Entry
[177] of java.util.HashMap$Entry[256]
m of java.util.Collections$SynchronizedMap
listeners of org.eclipse.e4.core.internal.contexts.EclipseContext
context of org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl
val$part of org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$2
[46] of org.eclipse.swt.widgets.Control[1024]
controlTable of org.eclipse.swt.widgets.Display [JNI Global, Stack Local]
Panneer
Re: Memory leak in TrackableComputaionExt [message #1006380 is a reply to message #1006373] Thu, 31 January 2013 02:57 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Please file a bug with this information and if possible a test case.
Tom
Am 31.01.13 08:20, schrieb Panneer Selvam:
> expression of
> listeners of
> context of
> val$part of
> Stack Local]
> Panneer
Re: Memory leak in TrackableComputaionExt [message #1006399 is a reply to message #1006380] Thu, 31 January 2013 04:10 Go to previous message
I have filed a bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399588
Previous Topic:Part specific toolbar buttons
Next Topic:Showing properties of e4 view selection in 3.x Properties view
Current Time: Sat May 25 01:44:33 EDT 2013
Powered by FUDForum. Page generated in 0.01904 seconds
