Home » Newcomers » Newcomers » Eclipse launcher unable for find shared library error(Unable to launch eclipse.)
Eclipse launcher unable for find shared library error [message #1006310] Wed, 30 January 2013 13:57 Go to next message
john.garrett@st.com Garrett is currently offline john.garrett@st.com Garrett
I downloaded and unzipped eclipse-cpp-juno-win32-x86-64.zip. I have Java(TM) SE Runtime Environment (build 1.6.0_07-b06) installed. Whenever I launce eclipse.exe I get an errror dialog displayed stating "The Eclipse executable launcher was unable to locate its companion shared library. I get the same error message when using eclipse downloaded with eclipse-jee-juno-SR1-win32-x86_64.zip. I've tried searching the eclipse executable for the shared library name, but was unable to find a string matching a shared library (*.dll). The eclipse.ini file has reference to a launcher.library entry. The path listed with the launcher.library exists with an eclipse_1503.dll file within it. I tried adding the dll file name to the path, but it didn't solve the problem. Any help will be greatly appreciated.
Re: Eclipse launcher unable for find shared library error [message #1006367 is a reply to message #1006310] Thu, 31 January 2013 00:15 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
John,
Is the JRE being used by your launcher (and used within your IDE as the
target) also a 64 bit JRE?
Re: Eclipse launcher unable for find shared library error [message #1008070 is a reply to message #1006310] Fri, 08 February 2013 12:36 Go to previous message
Lorenzo Bettini is currently offline Lorenzo Bettini
Although I'm not using windows much, this error happened to me as well
when I unzipped eclipse into a deep folder structure (don't remember the
number of folders...)
have you tried unzipping it, let's say, into C:\ directly?
hope this helps
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
HOME: http://www.lorenzobettini.it
Previous Topic:PyDev (on Aptana (on Eclipse 3.7)) - install extension via marketplace
Next Topic:eclipse juno create c++ project from source files tree
Current Time: Mon May 20 20:57:17 EDT 2013
Powered by FUDForum. Page generated in 0.01609 seconds
