Home » Eclipse Projects » SWTBot » How to using Enter key on a text box
How to using Enter key on a text box [message #1006109] Tue, 29 January 2013 18:20 Go to next message
manali pattem is currently offline manali pattem
I have been trying to use the enter key on a text box but somehow i can never get it working.I dont have any errors but it does not click enter.
Situation is I have a text box and i need to fill in a text and click enter and only then i have items that load . I have been trying this code
setText(labelname, text, dialogtitle);
key.pressShortcut(SWT.CR,SWT.LF);
Could anyone help me out on how to get this working??
Here is the screenshot
Capture.jpg index.php/fa/13150/0/ shows before clicking enter
Capture2.jpg index.php/fa/13151/0/ shows after clicking enter
  • Attachment: Capture.JPG
    (Size: 23.77KB, Downloaded 145 times)
  • Attachment: Capture2.JPG
    (Size: 21.75KB, Downloaded 143 times)
Re: How to using Enter key on a text box [message #1006223 is a reply to message #1006109] Wed, 30 January 2013 08:52 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk Fauth
I think you need to call pressShortcut on the Text control instead of a key, as you want to press a key while the text control has the focus. At least this is how I understand it.
Re: How to using Enter key on a text box [message #1006312 is a reply to message #1006223] Wed, 30 January 2013 14:04 Go to previous messageGo to next message
Hey Dirk,
Yeah i tried that too.But it doesnt work.DO we need to add anything else for this to work??
SWTBotText botText = bot.text("High-level qualifier:");
botText.pressShortcut(SWT.CR,SWT.LF);
Re: How to using Enter key on a text box [message #1006382 is a reply to message #1006312] Thu, 31 January 2013 03:13 Go to previous messageGo to next message
Well, two questions on that, do you have the correct text reference? As it seems you like to get a Text control for a label, but you are using the method for searching a Text control for the specified text. Otherwise you should use textWithLabel() or something that fits your needs.
If you have the correct reference, than maybe you need to first set the focus to the control.
Re: How to using Enter key on a text box [message #1006389 is a reply to message #1006312] Thu, 31 January 2013 03:34 Go to previous message
Mickael Istria is currently offline Mickael Istria
On 01/30/2013 08:04 PM, manali pattem wrote:
> Hey Dirk,
Have you read this: http://www.eclipse.org/forums/index.php/t/14207/ ?
pressShortcut won't work because it sends events simultaneously, whereas
the ENTER key usually sends 2 successive events.
Maybe botText.typeText(KeyStroke.getInstance(SWT.CR) + " " +
KeyStroke.getInstance(SWT.LF), 0)
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Previous Topic:SWTBot for custom SWT control
Next Topic:View Toolbar button issue while SWTBot and Eclipse Juno
Current Time: Wed May 22 14:50:19 EDT 2013
Powered by FUDForum. Page generated in 0.01606 seconds
