Hudson 2.0 CVS checkout issue [message #1006081] |
Tue, 29 January 2013 14:27 |
Srinivas Jonnalagadda Messages: 1 Registered: January 2013 |
Junior Member |
I use hudson 2.0 with CVS as SCM. When i check out projects in HUDSON cvs doesnt not check out CVS folder Which is the meta data folder in each directory. when i run an ANT script it does copy. My problem is that i have abuild.properties file that our application update with a build numner and commits the file. When we run ANT out of hudson this commit happens cussessful. but when we run from Hudson the commit fails because we suspect that is is due to the absence of CVS folder while checkout.
How to make sure that cvs folder is also checked out?
Thanks in advance for the help.
Sincerely,
srinivas J
FUDForum. Page generated in 0.01486 seconds
