Home » Eclipse Projects » Buckminster » Specifying a specific set of ws/os/arch for a p2 site
Specifying a specific set of ws/os/arch for a p2 site [message #998098] Wed, 09 January 2013 06:18 Go to next message
Tobias Bertelsen is currently offline Tobias Bertelsen
Hi there.
I will like to create a P2 site for a specific list of ws/os/arch combinations, e.g., win32,win32,x86, and cocoa,macosx,x64 but nothing else.
The situation
As I see the current solution I have these options:
1. Create a P2 site for only only one ws/os/arch combination
2. Use '*' to create a p2 for all platforms.
As all of ws/os/arch differs, I must use */*/*.
As I only have support for win32,win32,x86, and cocoa,macosx,x64 I can do one of two workarounds. Both are pretty bad i my oppinion:
1. Create bogus bundles for all other platforms, and create a p2 site for all platforms, that only work for some
2. Create different p2 sites, meaning more work building and more confusion from the user side.
I have looked in the buckminster source code, more specifically
org.eclipse.buckminster.pde.internal.actor.P2SiteGenerator.getConfigurations()
It seems to me, that using '*' is really my only option, but it can be changed rather simple by changing that method.
The question
Am I missing some smart trick, that allows me to specify a specific list of environments?
The suggestion
If it is not possible, could you consider adding this functionality. I'm thinking something like this:
The user specifies a property 'target.environments' with a list of environments, that take priority over the normal ws/os/arch properties:
E.g. The user specifies:
target.environments=win32.win32.x86;cocoa.macosx.x64
In the start of getConfigurations() the following is added:
String environments = props.get("target.environments").toString();
if(environments != null) {
  return environments.split(';');
Thanks for all your work Smile
Tobias
[Updated on: Wed, 09 January 2013 06:19]
Report message to a moderator
Re: Specifying a specific set of ws/os/arch for a p2 site [message #998148 is a reply to message #998098] Wed, 09 January 2013 07:51 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik Lindberg
I wonder if there may be a misunderstanding. When you are building a p2
site the architectures (etc) are used as filters regarding what to
include in the created p2 repository - it does not mean that all of them
needs to be present.
So, surely, there is never the need to create dummy bundles etc.
Later, when you build a product (if you do), then you build one at a
time with (for each wanted architecture).
In fact, if you have no desire to support some environments (i.e. it
does not actually work) then specify this in your bundles - this way you
prevent them to be installed in an environment you do not support.
Hope that helps
- henrik
On 2013-09-01 12:18, Tobias Bertelsen wrote:
> Hi there.
> The situation
> org.eclipse.buckminster.pde.internal.actor.P2SiteGenerator.getConfigurations()It
> The question
> of environments?
> The suggestion
> String environments = props.get(target.environments).toString();
> Thanks for all your work :) Tobias
Re: Specifying a specific set of ws/os/arch for a p2 site [message #1001210 is a reply to message #998148] Wed, 16 January 2013 03:52 Go to previous messageGo to next message
... it does not mean that all of them needs to be present.
OK, thought so. I'll try to see if this is actually a problem with our feature structure.
Thanks Smile
Re: Specifying a specific set of ws/os/arch for a p2 site [message #1004270 is a reply to message #998148] Tue, 22 January 2013 17:31 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo Bettini
Let me jump into this thread since I have a similar problem:
say that I want to build my site (and my products) only for these
combinations
os="linux,macosx,win32"
ws="cocoa,gtk,win32"
arch="x86,x86_64"
during materialization (of the TP) I can exclude the other architectures
with advisor nodes, e.g.,
<cq:advisorNode namePattern=".*\.solaris.*" skipComponent="true"/>
and, then equinox launchers (for instance) are not included for these
architectures...
but then, when I build the site.p2 I cannot specify the desired
combinations: I can only specify in the properties file
target.os=*
target.ws=*
target.arch=*
and the action fails due to
No component named
org.eclipse.equinox.launcher.gtk.solaris.sparc:osgi.bundle/[1.1.200.v20120522-1813,1.1.200.v20120522-1813](&(target.arch=sparc)(target.os=solaris)(target.ws=gtk))
is known to Buckminster
how could then avoid this problem?
rationale: I'd have no problem in getting into the TP and in the site.p2
all available combinations, but I'd like to materialize the TP against a
local mirror built with the b3 aggregator (and possibly install the
products reusing this mirror), and, as far as I understand, in the
b3aggr you must specify manually all valid architecture combinations,
you can't just say * (and I'd like to avoid specifying here also the
combinations I'm not interested in).
thanks in advance
Lorenzo
> Hope that helps
> - henrik
>> Hi there.
>> else.
>> The situation
>> The question
>> of environments?
>> The suggestion
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
HOME: http://www.lorenzobettini.it
Re: Specifying a specific set of ws/os/arch for a p2 site [message #1006056 is a reply to message #1004270] Tue, 29 January 2013 11:17 Go to previous messageGo to next message
Matthew Webber is currently offline Matthew Webber
My understanding is that you need the equinox launchers for ALL platforms in your tp/ when you build the p2 site, otherwise you get the
No component named
that you noticed.
I think the simplest solution is just to accept that, rather than try and trim down your tp/. We did that and it works fine.
Re: Specifying a specific set of ws/os/arch for a p2 site [message #1006410 is a reply to message #1006056] Thu, 31 January 2013 04:33 Go to previous message
> No component named
> that you noticed.
Yes, I understand, and I've also done that.
I was only concerned about the impossibility to create a p2 site for
only some selected platforms (Tycho allows you to do that, for instance).
Furthermore, since it is possible to create a p2 site for just one
platform, I guess it would be nice to have also the possibility to
select only some platforms :)
cheers
Lorenzo
Previous Topic:[Buckminster headless] Workspace overlap error
Next Topic:Not able to send email after build runs..
Current Time: Tue May 21 07:03:37 EDT 2013
Powered by FUDForum. Page generated in 0.02333 seconds
