| Re: How to turn text in label or label for 90grad ? [message #1016886 is a reply to message #1016786] |
Thu, 07 March 2013 23:53   |
The rotated text item creates an image, I believe. The standard XLS emitter does not support images. This is probably why it doesn't work for you in XLS. If you try another XLS emitter, like this one: BIRT Exchange Marketplace - Spud Soft BIRT Excel Emitters, it might work for you, cause there is image support. You might give it a try. As far as the other outputs, it should at least work in pdf, but I don't see why the others wouldn't work, as well. The code for creating the rotated text element can be found in the BIRT source code. For 4.2.2, you might have to go get the source and build the plugin project yourself.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
FUDForum. Page generated in 0.01756 seconds
