| [CDO] remove object from resource throws UnsupportedOperationException [message #1006004] |
Tue, 29 January 2013 09:22  |
Ricky de Klerck Messages: 282 Registered: January 2011 |
I'm trying to remove an object from a CDOResource, but when doing a resource.save() an exception is thrown..
This is the code:
IStructuredSelection sel = (IStructuredSelection) tableViewer.getSelection();
if(sel.getFirstElement() != null){
Person p = (Person) sel.getFirstElement();
personResource.getContents().remove(p);
try {
personResource.save(null);
} catch (IOException e1) {
e1.printStackTrace();
And this is the exception:
Caused by: java.lang.UnsupportedOperationException
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitDelegationRequest.getObjectType(CommitDelegationRequest.java:59)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.requestingCommit(CommitTransactionRequest.java:222)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactionRequest.requesting(CommitTransactionRequest.java:128)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequestWithMonitoring.requesting(CDOClientRequestWithMonitoring.java:91)
at org.eclipse.net4j.signal.RequestWithMonitoring.requesting(RequestWithMonitoring.java:165)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedOutput(RequestWithConfirmation.java:119)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:298)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:104)
at org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(RequestWithMonitoring.java:235)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:431)
at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
at org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestWithMonitoring.java:110)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:518)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.commitDelegation(CDOClientProtocol.java:405)
at org.eclipse.emf.cdo.internal.server.syncing.SynchronizableRepository$WriteThroughCommitContext.commit(SynchronizableRepository.java:975)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$2.runLoop(InternalCommitContext.java:56)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$2.runLoop(InternalCommitContext.java:1)
at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
at org.eclipse.emf.cdo.internal.server.Repository.commitUnsynced(Repository.java:917)
at org.eclipse.emf.cdo.internal.server.Repository.commit(Repository.java:910)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:295)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:97)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:86)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:92)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:65)
What am I doing wrong here?
FUDForum. Page generated in 0.02693 seconds
