| org.eclipse.emf.mwe.utils.Reader is not reading stereotype [message #1005992] |
Tue, 29 January 2013 08:50  |
Prodipta Mondal Messages: 8 Registered: January 2013 |
Junior Member |
Hi ,
I am trying to read .emx file using normal mwe workflow.I am not able to figure out why it's getting the stereoTyped elements of the model.Please find the complete workflow below.I am also attaching the model and profile which I am trying to generate.
<?xml version="1.0"?>
<workflow>
<!--Store Global Vars-->
<component class="com.accn.oaw.component.common.StoreGlobalVars" skipOnErrors="true">
<globalVarDef name="target_workspace" value="${target_workspace}"/>
<globalVarDef name="project_name" value="${project_name}"/>
<globalVarDef name="package_prefix" value="${package_prefix}"/>
</component>
<component class="com.accn.oaw.component.common.RSASetup">
<extensionMap from="efx" to="org.eclipse.uml2.uml.resource.UMLResource" />
<init value="true" />
</component>
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup">
<registerGeneratedEPackage value="org.eclipse.gmf.runtime.notation.NotationPackage"/>
<registerGeneratedEPackage value="com.ibm.xtools.umlnotation.UmlnotationPackage"/>
<platformUri value="${model_workspace}"/>
</bean>
<component id="read" class="org.eclipse.emf.mwe.utils.Reader">
<uri value="${inputmodel.file}"/>
<modelSlot value="model"/>
</component>
<bean class="org.eclipse.xtend.typesystem.emf.EmfMetaModel" id="metaModelId">
<metaModelFile value="com/accn/ecoremetamodel/common/MetaModel.ecore"/>
</bean>
<!-- transform model -->
<component class="org.eclipse.xtend.XtendComponent">
<metaModel class="org.eclipse.xtend.typesystem.uml2.profile.ProfileMetaModel">
<profile value="com/accn/ecoremetamodel/common/Profile.profile.uml"/>
</metaModel>
<invoke value="com::accn::oaw::m2m::common::Transform::transformModel(model)"/>
<outputSlot value="transformedModel"/>
</component>
<!-- Generate Code -->
<component class="org.eclipse.xpand2.Generator">
<metaModel idRef="metaModelId"/>
<metaModel class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel"/>
<expand value="com::accn::expand::atomicservices::TemplateACS::root FOR transformedModel"/>
<outlet path="${target_workspace}"/>
<beautifier class="org.eclipse.xpand2.output.JavaBeautifier" configFile="CodeFormatter.xml"/>
</component>
</workflow>
Any suggestion would be appreciated.Thanks in advance.
FUDForum. Page generated in 0.01400 seconds
