Home » Eclipse Projects » Virgo » Should Spring 3.0.7 be supported by Virgo 3.6?
Should Spring 3.0.7 be supported by Virgo 3.6? [message #1001886] Thu, 17 January 2013 09:10 Go to next message
Jean-Pierre Bergamin is currently offline Jean-Pierre Bergamin
Member
Hello Virgo users
We tried to use Spring 3.0.7 with Virgo 3.6 and hit this bug. But anyway... Is this just a bug and Spring 3.0.7 should work or will there be no support for 3.0.7 at all in Virgo 3.6?
James
[Updated on: Thu, 17 January 2013 09:25]
Report message to a moderator
Re: Should Spring 3.0.7 be supported by Virgo 3.6? [message #1005956 is a reply to message #1001886] Tue, 29 January 2013 07:06 Go to previous message
Glyn Normington is currently offline Glyn Normington
As per the bug, Virgo 3.6 requires Spring framework 3.1 or later.
Previous Topic:Eclipse like extension points in WebApp
Next Topic:Too low performance of legacy WAR-application
Current Time: Sat May 18 13:49:51 EDT 2013
Powered by FUDForum. Page generated in 0.01491 seconds
