| [Xbase] LValue-like expressions in DSL [message #1005779] |
Mon, 28 January 2013 12:11  |
Boris Brodski Messages: 55 Registered: July 2009 |
Member |
I develop a little xbase-language, that should specify mapping between DTO classes. Example:
Java:
class MyOldDTO {
private long id;
public long getId() {return id;}
public void setId(long id) {this.id=id;}
class MyOldDTO {
private long number;
public long getNumber() {return number;}
public void setNumber(long id) {this.number=number;}
Mapping-DSL:
mapping(MyNewDTO n, MyOldDTO o) {
n.id <===> o.number
// Could also be:
// n.child.otherDTO.value <===> o.nodes.value
From this model I would like to generate following java snippets:
// Old to New
n.setId(o.getNumber());
// New to Old
o.setNumber(n.getId());
So, the idea of grammar is to accept something like
left=XAssignable '<===>' right=XAssignable
where XAssignable is an 'lvalue'-like Xbase-expression (expression, that can be read and assigned).
Do you have any ideas, how this could be implemented?
Thanks a lot!
Boris Brodski
| Re: [Xbase] LValue-like expressions in DSL [message #1005873 is a reply to message #1005779] |
Tue, 29 January 2013 02:23   |
Sebastian Zarnekow Messages: 2788 Registered: July 2009 |
Hi Boris,
if I understood you correctly, you'd like to map a single feature call
to two different features. I'm afraid this is not straight forward and
cannot be done easily. You'd have to customize scoping heavily (sort of
introduce an artificial mapping feature that points to the getter and
setter where the feature call (id / number) points to that artificial
thing. Nevertheless you'd have to deal with a lot of stuff regarding
creation of children on demand et al.
To put a long story short: A lot of effort and deep digging into the
scoping thing. I recommend to wait for 2.4 before you start serious
efforts on this one.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 28.01.13 18:11, schrieb Boris Brodski:
> Hello,
> Java:
> class MyOldDTO {
> private long id;
> class MyOldDTO {
> Mapping-DSL:
> n.id <===> o.number
> // Could also be:
> // Old to New
> // New to Old
> Thanks a lot!
> Boris Brodski
FUDForum. Page generated in 0.05006 seconds
