Home » Modeling » TMF (Xtext) » Dynamic Syntax Highlighting
Dynamic Syntax Highlighting [message #1005843] Mon, 28 January 2013 18:46 Go to next message
Nathan M is currently offline Nathan M
I'm wondering if it's possible to have some text in the editor get a certain TextStyle that isn't known until runtime.
For example, if in the editor the user types "#ffff00", I want the text to be yellow, if the user types "#ff0000" I want the text to be red, etc... Basically I don't know what the color of the text actually is until I have analyzed the user input.
Is there a way to do this?
[Updated on: Mon, 28 January 2013 20:26]
Report message to a moderator
Re: Dynamic Syntax Highlightinh [message #1005863 is a reply to message #1005843] Tue, 29 January 2013 01:14 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
Yes this is possible. The term is semantic highlighting
http://www.eclipse.org/Xtext/documentation.html#highlighting
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
[Updated on: Tue, 29 January 2013 01:24]
Re: Dynamic Syntax Highlighting [message #1006716 is a reply to message #1005843] Fri, 01 February 2013 09:37 Go to previous message
True, but as far as I can tell, you must preregister the particular highlighting configurations. In other words, I don't see how you can dynamically change the color of some text based on the value of the text in the editor (not unless you predefined every possible color that can exist...)
Previous Topic:SAXParseException on running Maven build for test that builds an Xtext model
Next Topic:CSS Validation
Current Time: Thu May 23 11:22:59 EDT 2013
Powered by FUDForum. Page generated in 0.08372 seconds
