| Annoying error with "Open Type Hierarchy action" [message #910169] |
Sat, 08 September 2012 18:14  |
Olivier Leduc Messages: 1 Registered: September 2012 |
Junior Member |
I have this very annoying error box that keeps popping up when I click a variable or a method referenced used $this.
Here is the error:
An internal error occurred during: "Open Type Hierarchy action".
org.eclipse.dltk.ast.ASTNode.end()I
class myPlugin {
private $_sites;
private $_path;
public function __construct(){
$this->_sites = $this->initSites();
private function initSites(){
//Scan for sites in sites/ directory
//Return site names
return $sites;
Thank you for your help!
| Re: Annoying error with "Open Type Hierarchy action" [message #932126 is a reply to message #910169] |
Wed, 03 October 2012 17:26   |
Pavel Tucha Messages: 1 Registered: October 2012 |
Junior Member |
I have the same problem, but in my case it happen not only on $this references. Sorry, i can not find what exactly raise this error: error message opens each few minutes on completly defferent actions or even without them.
It started with moving to PDT 3.1.1 and reproduced on Eclipse Indigo 3.7.1 Build id: 20110615-0604
Is there anywhere binary build of earlier PDT version (3.1.0 or 3.0.x)?
[Updated on: Wed, 03 October 2012 17:46] Report message to a moderator
| Re: Annoying error with "Open Type Hierarchy action" [message #1005763 is a reply to message #995940] |
Mon, 28 January 2013 11:16  |
Amenel Voglozin Messages: 16 Registered: September 2009 |
Junior Member |
@Toshihiro Izumi: Thanks a ton! Your solution worked fine for me.
[EDIT] Actually, it worked until I moved on to a C++ project. And it seems like the solution (I applied item #3) does damage CDT somehow: although the build ends fine, scores of errors appear in the Problems view with their corresponding error markers in the editor view, which is immensely annoying. I'll go back to a zipped Indigo installation I had put aside for cases like this. My many thanks still stand.
[Updated on: Mon, 28 January 2013 16:41] Report message to a moderator
FUDForum. Page generated in 0.01783 seconds
