Home » Modeling » ATL » In-place refining mode is now available for EMFTVM
In-place refining mode is now available for EMFTVM [message #997669] Mon, 07 January 2013 14:31 Go to next message
Dennis Wagelaar is currently offline Dennis Wagelaar
Member
[first attempt failed, so here it is again]
In-place refining mode is now available for EMFTVM: grab version
3.4.0.201301051207 from:
http://soft.vub.ac.be/eclipse/update-3.7/
Documentation at:
http://wiki.eclipse.org/ATL/EMFTVM#In-place_transformation
Small changes:
- Added OclType::refInvokeStaticOperation(opname : String, args :
Sequence(OclAny)) to allow static Java method invocation. Use like this:
"#native"!"java::lang::Long".refInvokeStaticOperation('valueOf', Sequence{'1'}).
- Added Sequence::includingRange(start : Integer, end : Integer) as a
work-around for the Sequence{start..end} idiom. Use like this:
Sequence{}->includingRange(0, 100)
Dennis
Re: In-place refining mode is now available for EMFTVM [message #1005705 is a reply to message #997669] Mon, 28 January 2013 06:00 Go to previous messageGo to next message
Skander Turki is currently offline Skander Turki
Hi Dennis,
Is it possible, using this new in-place refining mode to implement models' synchronization? I suppose we would need two transformations, one for each direction. And also two higher-order transformations to reduce (comment out) the rules that should not participate in the update transformation each time a synchronization is needed.
Does it seem to be a good approach for you?
Thanks in advance.
Re: In-place refining mode is now available for EMFTVM [message #1005820 is a reply to message #1005705] Mon, 28 January 2013 15:32 Go to previous messageGo to next message
Member
Op 28-01-13 12:00, Skander Mising name schreef:
> Hi Dennis,
Yes, indeed. In the EMFTVM launch dialog as well as the Ant tasks, you can
specify IN/OUT models. These IN/OUT models can either be new or existing models.
> Thanks in advance.
Hmm, an update transformation should rather test for the existence of target
model contents. Something like this:
rule MyRule {
from s : SMM!Source (TMM!Target.allInstance()->forAll(t | t.name <> s.name))
to t : TMM!Target (...)
rule MyRuleExisting {
from t : TMM!Target,
s : SMM!Source (s.name = t.name)
to t1 : TMM!Target mapsTo t (...)
Perhaps you can write a HOT to generate the MyRule/MyRuleExisting rule pair
out of regular transformation rules. See what works for you...
Dennis
Re: In-place refining mode is now available for EMFTVM [message #1006005 is a reply to message #1005820] Tue, 29 January 2013 09:23 Go to previous messageGo to next message
Thanks for your reply.
So what I understand is that you have to write manually your refinement rules. I mean there is no support for incremental transformations;
Do you know if it is planned in the future ATL versions?
Re: In-place refining mode is now available for EMFTVM [message #1006091 is a reply to message #1006005] Tue, 29 January 2013 15:21 Go to previous messageGo to next message
Member
> I mean there is no support for incremental transformations; Do you know if it
> Thanks
Indeed, ATL does not have built-in support for incremental/synchronisation
transformations, such as QVT-R allows for example.
There are no plans for developing this as far as I know. Current EMFTVM
technology may have to be updated for this: simple one-to-one refinement rules
can be mapped to a "create" and an "update" version of the rule, but if there
are multiple output elements, a combinatorial explosion of all create/update
combinations must be dealt with.
Dennis
Re: In-place refining mode is now available for EMFTVM [message #1006402 is a reply to message #1006091] Thu, 31 January 2013 04:19 Go to previous message
Thanks a lot for this valuable information.
Previous Topic:ATL File usging second ATL File and input variable of ATL File
Next Topic:Runtime exception handling?
Current Time: Fri May 24 09:30:04 EDT 2013
Powered by FUDForum. Page generated in 2.42188 seconds
