Home » Modeling » EMF » Create proxy object for abstract reference type
Create proxy object for abstract reference type [message #1005637] Sun, 27 January 2013 16:34 Go to next message
David Rees is currently offline David Rees
Member
We are trying to create a proxy object for a cross-resource EReference where the other resource has not been loaded yet. So we can't just grab its EObject.
I found this approach from Ed at http://www.eclipse.org/forums/index.php/mv/msg/205677/658272/#msg_658272:
Ed Merks wrote on Mon, 07 March 2011 11:26
Given some EObject x that's a resolved proxy held by feature f of object
y, you can use EcoreUtil.create(x.eClass()), cast it to InternalEObject,
call setEProxyURI with EcoreUtil.getURI(x), and then use
EcoreUtil.replace(y, f, x, <that proxy object>).
The problem we are running into is that this approach doesn't work when the EReference's type is abstract. Instead EcoreUtil.create throws an IllegalArgumentException with the message "The class XXX is not a valid classifier".
The only workaround we have found so far is to remove the abstract flag from the EReference's EClass type. We'd prefer not to do that since the base class really is abstract, and if/when the proxy is resolved it will resolve to the proper subclass.
Is there another approach? On the surface I don't see why we can't have a proxy object of the abstract class's type that will resolve to a concerete class type. Since EReference attributes don't contain type information this doesn't seem to be a requirement in the serialization format either.
dave
Re: Create proxy object for abstract reference type [message #1005662 is a reply to message #1005637] Mon, 28 January 2013 01:54 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
David,
Comments below.
> grab its EObject.
>> object y, you can use EcoreUtil.create(x.eClass()), cast it to
>> InternalEObject, call setEProxyURI with EcoreUtil.getURI(x), and then
>> use EcoreUtil.replace(y, f, x, <that proxy object>).
That post was asking about converting an existing object back to a
proxy, not about creating a proxy out of thin air...
You need to determine a concrete subclass of the abstract class. That's
why in an XMI serialization there will always be an xsi/xmi type on such
a proxy reference...
It's not that you can't have one. The problem is, just as an in Java,
if you have an abstract class X, you can do "new X()", and you can't
even do it reflectively.
As I mentioned above, the serialization will always specify an xsi:type
in these cases because the actual object will be a concrete subclass and
creating a proxy requires that information.
Given you're trying to create a proxy for something instantiable, don't
you already know the non-abstract class of that something? Note that,
although it's quite odd, it's not necessary that the proxy will resolve
to an object that's a subclass of the proxy, so you could choose any
arbitrary concrete subclass for the proxy. But as I suggested with my
previous question, it seems odd that you'd know the proxy URI but not
know the type of the target for that URI...
> dave
Re: Create proxy object for abstract reference type [message #1005751 is a reply to message #1005662] Mon, 28 January 2013 09:52 Go to previous messageGo to next message
Member
Ed Merks wrote on Mon, 28 January 2013 01:54
David,
Comments below.
Yes, I know. Just wanted to point out where we got the original idea for the approach.
No we don't, that file may not have been loaded/created yet. For example we are loading a bunch of existing XML files that may contain keys (with no type info) for elements in files we have not processed yet. Happily the fact that proxies do not have to be resolved allows us to handle this case.
[quote]Note that, although it's quite odd, it's not necessary that the proxy will resolve
Thanks, we were wondering about this approach. It will let us avoid modifying the metamodel, but I guess we will need to be more careful when working with proxies. Actually, we have already figured out we need to be careful anyway since it seems if a resolve fails the instance just returns nil for all its features rather than throwing an error.
if you have an abstract class X, you can do "new Dead)", and you can't
Sorry, I'm missing the difference between "can't have one" and "can't create one". Are they not one and the same in this case or am I missing something?
At a theory level, we are not trying to instantiate the target instance, we are trying to instantiate its proxy which is practically possible in many other proxy frameworks. As you mentioned, even the EMF recognizes that its choice of proxy type is just a guess since it can change (and easily could since they are in different files).
And if the root class isn't abstract then EMF doesn't generate the xsi:types, further underscoring that EMF doesn't need them for resolving - it just needs them to get around the limitation on instantiating the abstract class instances (even as proxies). Still, I can understand if there are assumptions in the implementation that don't expect an abstract instance to exist even as a proxy.
Thanks! It's very helpful to understand the underlying logic.
dave
Re: Create proxy object for abstract reference type [message #1005758 is a reply to message #1005751] Mon, 28 January 2013 10:20 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
<body text="#000000" bgcolor="#FFFFFF">
David,<br>
<br>
Comments below.<br>
<br>
<div class="moz-cite-prefix">On 28/01/2013 3:52 PM, David Rees
wrote:<br>
</div>
<blockquote cite="mid:ke63c5$jbu$1@xxxxxxxxe.org" type="cite">Ed
<br>
<blockquote type="cite">David,
<br>
<br>
Comments below.
<br>
<br>
<br>
&gt; The problem we are running into is that this approach
doesn't work &gt; when the EReference's type is abstract.
<br>
a proxy, not about creating a proxy out of thin air...
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Given you're trying to create a proxy for
something instantiable, don't you already know the non-abstract
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
I see.<br>
<br>
<br>
<br>
<blockquote type="cite">&gt; Is there another approach? You need
on such a proxy reference...
<br>
</blockquote>
<br>
the proxy will resolve to an object that's a subclass of the
proxy, so you could choose any arbitrary concrete subclass for the
proxy.  But as I suggested with my previous question, it seems odd
that you'd know the proxy URI but not know the type of the target
for that URI...
<br>
<br>
rather than throwing an error. <br>
</blockquote>
Yes, generally a proxy has no populated features and carries only
the proxy URI.<br>
<blockquote cite="mid:ke63c5$jbu$1@xxxxxxxxe.org" type="cite">Quote:
<br>
<blockquote type="cite">&gt; On the surface I don't see why we
can't have a proxy object of the &gt; abstract class's type that
will resolve to a concerete class type. It's not that you can't
have one.  The problem is, just as an in Java, if you have an
abstract class X, you can do "new x()", and you can't even do it
reflectively.
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
Sorry, I meant you <b>cannot </b>do new X(). <br>
<br>
practically possible in many other proxy frameworks. </blockquote>
Yes, such as Java dynamic proxies, but in that case, it's also not
possible to reuse some existing base class.  I did investigate using
Java dynamic proxies to support this kind of thing for EMF, but it's
complicated by the fact all such objects also have to implement the
full InternalEObject API and must do so without extending
BasicEObjectImpl .  Proxies for bidirectional references would have
to properly implement that API.  I looked at how to do that by
delegation, but then you get into problems with == being used in the
framework for testing object equality always via identity.   Not
much good came of it...<br>
<blockquote cite="mid:ke63c5$jbu$1@xxxxxxxxe.org" type="cite">As
<br>
</blockquote>
No, I wouldn't characterize it that way.  When we serialize, we
write out a proxy URI when we know we'll need one during
deserialization.  It's not a guess, it's exactly the type of the
referenced thing.<br>
<br>
<br>
<blockquote type="cite">&gt; Since EReference attributes don't
contain type information this &gt; doesn't seem to be a
<br>
xsi:type in these cases because the actual object will be a
concrete subclass and creating a proxy requires that
information.
<br>
</blockquote>
<br>
<br>
resolving </blockquote>
It needs them for creating a proxy.  There might not even be a
concrete subclass within any  models known at that point, so it
can't pick some arbitrary guessed type...<br>
<blockquote cite="mid:ke63c5$jbu$1@xxxxxxxxe.org" type="cite">-
the abstract class instances (even as proxies).  </blockquote>
Yes.<br>
<blockquote cite="mid:ke63c5$jbu$1@xxxxxxxxe.org" type="cite">Still,
<br>
</blockquote>
Certainly something like EcoreUtil.copy would have problems with
that.   That's why I didn't suggest using new MyAbstractClass() {
/*stub methods*/ }, because it would definitely be odd for any
object x if x.eClass().isAbstract() is true.<br>
<br>
<br>
<br>
</blockquote>
You're welcome.  It is kind of an annoying limitation, but one for
which there appear to be no clean solutions.<br>
<blockquote cite="mid:ke63c5$jbu$1@xxxxxxxxe.org" type="cite">dave
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: Create proxy object for abstract reference type [message #1005761 is a reply to message #1005758] Mon, 28 January 2013 11:08 Go to previous message
Member
Thanks again for the insights. It definitely helps to know where the dragons are lurking Smile.
d
Previous Topic:Modifying the generated XML (model) from diagram
Next Topic:[CDO] Help to debug server-side commit operation
Current Time: Sat May 18 21:01:42 EDT 2013
Powered by FUDForum. Page generated in 0.01721 seconds
