| CSS Validation [message #1005557] |
Sat, 26 January 2013 12:10  |
Steven Spungin Messages: 4 Registered: December 2012 |
Junior Member |
I don't know if this is a bug or configuration issue on my part, but I downloaded the lastest build of xtend yesterday (2.4.0.v201301250856), and I am getting hundreds of this error in all of my CSS files:
extraneous input ' ' expecting RULE_IDENT {...} Xtext Check (fast)
It seems that any css rules that have '.' in the number cause this error, such as:
Furthermore, there does not seem to be a way to turn of the validation on the css files.
Has anybody else seen this issue?
| Re: CSS Validation [message #1005743 is a reply to message #1005727] |
Mon, 28 January 2013 08:46   |
Thomas Schindl Messages: 4463 Registered: July 2009 |
No offense taken ;-) - I guess because the parser is generated upgrading
Xtext to 2.4.0 can't lead to such a problem. So if it works with 2.3.1
it will still work with 2.4.0.
Knowing what Steven has installed would help to find out who is the one
to blame.
Tom
Am 28.01.13 13:31, schrieb Sebastian Zarnekow:
> Sorry Tom, didn't meant to blame e(fx)clipse for that one. The e4 css
> stuff sounds more likely to cause the issue.
> Sebastian
> Am 28.01.13 13:20, schrieb Tom Schindl:
>> e(fx)clipse is perfectly happy with .9em and translate it to what it is
>> 0.9em ;-) but I'm running with xtext 2.3.1 have not yet tried 2.4.0.
>> It could also be the e4 css editor, which is also based on xtext
>> Tom
>> Am 28.01.13 09:55, schrieb Sebastian Zarnekow:
>>> Am 27.01.13 15:07, schrieb Steven Spungin:
>>>> I do not see any installed plugin with xtext and css in the name.
>>>> Which
>>>> feature would have (or should have) installed the css validator?
>>> Probably e(fx)clipse? I'm not sure - don't know each and every
>>> application of Xtext.
>>> Regards,
>>> Sebastian
| Re: CSS Validation [message #1005871 is a reply to message #1005743] |
Tue, 29 January 2013 02:18   |
Sebastian Zarnekow Messages: 2788 Registered: July 2009 |
Hi Tom,
yes, upgrading to 2.4.0 but still using e(fx)clipse that was compiled to
2.3.1 will lead to all sorts of problems but not this one :-)
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 28.01.13 14:46, schrieb Tom Schindl:
> to blame.
> Tom
>> Regards,
>> Sebastian
>>> Tom
>>>>> Which
>>>> Regards,
>>>> Sebastian
| Re: CSS Validation [message #1006721 is a reply to message #1005557] |
Fri, 01 February 2013 10:10  |
Junior Member |
It definitely was the e4 CSS editor. I removed it (with xtext and xtend still installed) and the errors stopped.
It's having trouble parsing numbers that start with a '.'
I ran my CSS through lint and there were no errors. So this seems to be due to either the e4 CSS editor grammar, or a configuration issue on my end. Either way, it would be nice to be able suppress the errors.
If anybody has the latest e4 CSS editor installed, please let us know if this causes the error:
.ip-tutorial-info {
font-size: .9em;
FUDForum. Page generated in 0.01772 seconds
