Home » Modeling » EMF » Don't Get It - anyURI and ecore:reference
Don't Get It - anyURI and ecore:reference [message #1002145] Thu, 17 January 2013 21:54 Go to next message
Brandon Lewis is currently offline Brandon Lewis
I am using a publicly available IEEE schema for project. I have extended this schema by simply importing one of my own schemas into it.
The resulting genmodel, when I create a new EMF Project, has two main packages and ecore models generated. One ecore for each of the major schemas.
In my schema, I am trying to make a reference to something in the larger enclosing schema (the IEEE one). So I'm trying to use the in my own schema:
<xs:complexType name="controlType">
<xs:sequence>
<xs:element name="registerFieldRef" type="xs:anyURI" ecore:reference="fieldType" minOccurs="0" maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
fieldType is a ComplexType defined in another schema file (the larger public schema that "surrounds" my schema. Like this: <xs:complexType name="fieldType">
I have typed at least 50 different things in the ecore:reference="" quotes and I can't get anything generated out of EMF that doesn't create a reference to a generic EObject. I want a reference to FieldType (the Class that EMF correctly creates for the complexType "fieldType).
I have searched and found people trying to figure out how to get a reference to a generic EObject and not a specific type, but I'm trying to do the opposite - I want a specific type reference.
I don't get it. Does ecore:reference need to refer to a Java class or something within the schema? The package containing the EMF class I want to reference has not been created yet by the Model generator, so I don't understand how I could make a reference to that.
Re: Don't Get It - anyURI and ecore:reference [message #1002246 is a reply to message #1002145] Fri, 18 January 2013 03:39 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Brandon,
Comments below.
> schemas.
One for each namespace...
> my own schema:
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> name="fieldType">
> "fieldType).
You have to use exactly what you's put in the type="...". If what
you're trying doesn't work there (i.e., the schema validates it as
unresolved), it won't work in the ecore:reference either.
It needs to use a schema reference that would resolve if it were used as
an actual type in the schema. So you need an import and it needs to be
a QName that would resolve properly, so be sure you have an xmlns
declaration for that imported schema's namespace and be sure to use it
as part of you QName reference.
It needs to be a schema reference...
Re: Don't Get It - anyURI and ecore:reference [message #1005550 is a reply to message #1002246] Sat, 26 January 2013 08:41 Go to previous message
Thanks Ed! That answer perfectly cleared it up for me.
I was able to debug my problem by putting a type=".." reference in my schema and using my schema validator to tell me what I was doing wrong. Once I figured that out, I moved that over to the ecore:reference="..." part and it worked.
All good now. I appreciate your help.
> "fieldType).
Previous Topic:[CDO] Updating CDO references in XMI Resource
Next Topic:[CDO] 4.1 transaction rollback after a commit
Current Time: Mon May 20 01:47:35 EDT 2013
Powered by FUDForum. Page generated in 0.03523 seconds
