| Problem Unzipping [message #901885] |
Tue, 14 August 2012 17:33  |
Chris Stross Messages: 2 Registered: August 2012 |
Junior Member |
I went to unzip the Eclipse Download and got this message:
Extracting to "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\"
Use Path: yes Overlay Files: no
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\".
Extracting eclipse\.eclipseproduct
Extracting eclipse\eclipsec.exe
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\".
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\".
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\feature.properties
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\META-INF\".
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\META-INF\ECLIPSE_.SF
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\META-INF\ECLIPSE_.RSA
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\META-INF\eclipse.inf
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\META-INF\MANIFEST.MF
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\license.html
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\feature.xml
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\epl-v10.html
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\eclipse_update_120.jpg
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\".
Extracting eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\feature.properties
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\META-INF\".
Extracting eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\META-INF\ECLIPSE_.SF
Extracting eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\META-INF\ECLIPSE_.RSA
Extracting eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\META-INF\eclipse.inf
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\META-INF\maven\".
The path is too long. Unable to extract "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\META-INF\maven\org.eclipse.recommenders.feature".
Severe Error: Path for extracted file is too long; can't extract.
How can I fix this?
Thanks in advance
Chris Stross
| Re: Problem Unzipping [message #986261 is a reply to message #901885] |
Mon, 19 November 2012 11:32   |
Gabriel Nar Messages: 2 Registered: November 2012 |
Junior Member |
This is a Windows* OS/file system issue.The cause is the directory paths in the system is longer than 255 characters (including spaces).You may see the error "The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters," under the following circumstances:Opening an assembly with .NET Reflector
Exporting source code for an assembly using an add-in such as FileDisassembler, or FileGeneratorThere's a lot of additional softwares which can fix this problem like Long Path Tool.
PathTooDeep.com
Long Path Tool can simplify and probably end your problems in unlocking, managing and renaming files that appear to have a long filename. Since in some instances, you may have experienced problems accessing, managing and even renaming files that have
more than 255 characters, this utility has been made to answer this particular scenario. If you have also encountered problems like error messages that tell you
that the path too long, too long path, destination path too long or cannot delete file then this program is definitely for you. This will totally take place of
Windows Explorer, Far Manager or other file managing utilities since this is maybe used in any type of Operating System even the earliest Windows 95 version.
FUDForum. Page generated in 0.02680 seconds
